HDMI BenQW500 Connectivity - AVS Forum
post #1 of 2 Old 12-07-2008, 10:01 AM - Thread Starter
Keltie's Avatar
I just recently purchased a BenQW500, I am using BJC series F2 28AWG High flex HDMI cable fro Bluejeans. I have a 20 foot run. My issue is that each time I try to connect to my Bell HD receiver I have to play with the connection in order to get the projector to connect. I don't have this problem with the S Video or video connection. Is this a faulty projector or another issue. I tried a shorter 6 foot HDMI cable and had the same problem.
Ian
Keltie is offline
post #2 of 2 Old 12-08-2008, 11:41 AM
crutschow's Avatar
Do you mean every time you turn on the receiver and the projector, you have to connect and reconnect to get it to work? If so it may be an HDMI handshake protocol problem. Sometimes the order in which you turn the units on can be a factor in whether it works. For example, if you normally leave the receiver on, try turning it off and then back on after the projector is on.
Carl
Curmudgeon Elektroniker
crutschow is offline
Reply HDMI Q&A - The One Connector World
User Tag List
