Small connector or little molding on HDMI cables? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 03-30-2009, 06:09 AM - Thread Starter
zoma4's Avatar
Hey Everyone,
I am trying to mount my HDTV above my fireplace in my new home and not have any wires outside the wall. I have a conduit running from above the fireplace to a wall on the side of the room that is about 24' long. My problem is that my builder used 1/2" smurf tubing for the conduit, and I didn't realize until the home was finished that the HDMI cable head doesn't really fit in the tube. The actual cable head fits, but all of my cables have too much molding around the connector to fit in.
Is there anyone that sells HDMI cables with smaller heads or low-profile molding? If I can't get a cable into the tube, what are my other options?
-Matt
zoma4 is offline
post #2 of 13 Old 03-30-2009, 06:22 AM
localnet's Avatar
Originally Posted by zoma4 View Post
Hey Everyone,
-Matt
1/2"? Hmmm... Boy, I don't know of any that small. My suggestion, if you cannot find such a beast, is to use Cat5e or Cat6 cable and baluns. Check these out, many manufacturers out there, this is just one of many http://www.google.com/products/catal...ult#ps-sellers
localnet is offline
post #3 of 13 Old 04-13-2009, 05:50 AM - Thread Starter
zoma4's Avatar
Thanks localnet!
I ended up buying the TrippLite HDMI over Cat5/6 set (I used Cat6. It's working great for me! It's pretty easy to install, and the Cat 6 wires are punched down directly to the wall plate, so the head of the cable doesn't need to fit through the smurf tube.
Appreciate the help!
-Matt
zoma4 is offline
post #4 of 13 Old 04-13-2009, 08:55 AM
crutschow's Avatar
If anyone else has a similar problem there is also this HDMI cable http://www.provantage.com/tripp-lite...z~4TRPA1T6.htm with added small connectors that allows pulling through small conduit.
Carl
Curmudgeon Elektroniker
crutschow is offline
post #5 of 13 Old 04-13-2009, 10:06 AM
ChrisWiggles's Avatar
There is also the rapidrun cables that might work for you, in addition to the suggestions above.
ChrisWiggles is offline
post #6 of 13 Old 05-12-2009, 03:19 AM
RapalloAV's Avatar
Quoted: 1646 Post(s)
Liked: 479
HDMI over Single Wire cat5/6 cable also works great and saves more space too than the twin cat5.
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is offline
post #7 of 13 Old 05-12-2009, 03:42 AM
localnet's Avatar
Have you tried one of those single wire HDMI units? I have allot of Intelix baluns in my house, and spoke to one of their techs regarding single cat5e or 6 HDMI baluns. He told me they are working on them, but have not had favorable results. If you have, or are using these single wire HDMI units, what do you think, do they work well passing the voice and video?
Mike
localnet is offline
post #8 of 13 Old 05-12-2009, 03:58 AM
RapalloAV's Avatar
Liked: 479
Mike
Can you show me the ones that dont work well please?
Murray Thompson
X Owner RapalloAV
post #9 of 13 Old 05-12-2009, 04:08 AM
localnet's Avatar
I have seen some reviews on some sites where there were problems with these single cable units. I was just wondering if you have had any luck. I didn't want to drop $100+ on something that was questionable. The only reason I asked, and the guys at Intelix were very convincing when talking actual engineering and the problems with sending an HDMI signal over one cable. No brands or manufacturers were ever mentioned.
I would like to know for a possible future project, as I am limited on actual Cat5e runs. Right now I am using component baluns and pumping the sound through my whole house audio system to a couple of rooms. It would be nice to do it all with a single HDMI/Cat5e run. That is why I asked because I don't know.
Mike
localnet is offline
post #10 of 13 Old 05-12-2009, 01:43 PM
RapalloAV's Avatar
Liked: 479
Mike
I will do some more testing on these and get back to you on this.
Murray Thompson
X Owner RapalloAV
post #11 of 13 Old 05-12-2009, 04:21 PM
RapalloAV's Avatar
Liked: 479
Mike
Ok Ive just bench tested a SINGLE cat6 cable through the (Single cat5/6 to HDMI Extender) and its working FANTASTIC! These are new ones on the market and maybe better than the ones you have heard about.Im very very happy with the results, I will now take one home an test on a 15M run of cat6 I have installed in the walls
BTW these baluns are "both powered each end" unlike twin cat5 baluns being powered one end.
Murray Thompson
X Owner RapalloAV
post #12 of 13 Old 05-12-2009, 07:10 PM
Richard Paul's Avatar
Quoted: 32 Post(s)
Liked: 36
An issue with single Cat 5/6 HDMI extenders is that they have to multiplex the data signals (HDMI has more data wires than a Cat 5/6 cable). The multiplexing of the data signals has to be done exactly right or it will cause problems. From what I have read dual Cat 5/6 HDMI extenders are usually more reliable since they don't have to multiplex the data signals.
Richard Paul is offline
post #13 of 13 Old 05-14-2009, 01:40 AM
RapalloAV's Avatar
Liked: 479
Mike
Ok Ive just tested the SINGLE cat5e/6 Extenders with ONE 15M cat5e cable and it works perfectly! 1080P and all the audio tracks, nice simple and easy to use. This is a great product for people who either already only have one cat5e cable in the wall or no room for adding more than one.
Murray Thompson
X Owner RapalloAV
Reply HDMI Q&A - The One Connector World
