could my HDMI be the problem? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-07-2009, 08:48 AM - Thread Starter
kpc01's Avatar
I have a very wierd problem. I have a Sony 1080p tv and have it hooked to a Samsung BR player(I switch this out with a PS3 as well) and a motorola hd cable box.
the TV is perfect with the PS3 and with the BR player, but when I am watching HD tv the sound will randomly cut out for 2-5 seconds. it might not do it for 20 minutes then it will do it 3 times in a row. I have swapped inputs on the tv and swapped my two hdmi cables. I have also had the cable company try different tuners. BTW, it does not do it on NON HD stations.
the tuner is a DVR and I noticed that if I have a HD show recorded I can backup to the spot it cut out and it won't cut out. so the signal is there, just not coming out on the TV. I have no idea what could cause this and desperate for some help! any advice?
Just trying to keep up...
kpc01 is offline
post #2 of 4 Old 10-07-2009, 09:09 AM
crutschow's Avatar
Sounds like some sort of audio sync problem between the TV and the cable box. Are there any options on the TV or the cable box for the digital sound format, such as Dolby or PCM? If so, you might try playing with those.
The HDMI cable is not the cause since both video and audio are transmitted on the same lines, and you have no video problem.
Carl
Curmudgeon Elektroniker
crutschow is offline
post #3 of 4 Old 10-07-2009, 09:20 AM - Thread Starter
kpc01's Avatar
I've played with everything on the TV and I also have the audio output going to a receiver. the sound will do it on both the tv and the reciever.
I figured it was the cable box but when I rewind and it works fine it had me wondering. funny part is that the picture is always perfect. I would think the picture would require more signal than the sound
thanks for the tips
kpc01 is offline
post #4 of 4 Old 10-07-2009, 09:42 AM
crutschow's Avatar
thanks for the tips
Are there any audio options on the cable box?
Yes, the video requires a much greater bandwidth (at least a factor of 100) more than the audio.
Carl
Reply HDMI Q&A - The One Connector World
