HDMI-DVI picture interference - AVS Forum | Home Theater Discussions And Reviews
Old 01-03-2010, 07:55 AM - Thread Starter
Likvid's Avatar
I have some annoying picture interference problems when connecting to my plasma and it's only from this source i have this problem with, all other HDMI equipment work good.
If you look at the picture i have attached you will see, anyone seen anything like that before and what's causing it? i have even tried different cables and the same result.
Please help.
Likvid is offline
Old 01-03-2010, 04:34 PM
ChrisWiggles's Avatar
what is this source? It may be the source is screwed up somehow?
ChrisWiggles is offline
Old 01-03-2010, 05:48 PM - Thread Starter
Likvid's Avatar
It's a Linux based open source satellite receiver, with the official software loaded i get the interference above, if i however load 3rd part software developed for it i get no interference.
The difference is that 3rd part software has HDCP disabled, i can not use 3rd part software for other reasons so it doesn't solve the problem for me.
I am still investigating how to solve this and have emailed the manufacturer about this problem.
Likvid is offline
Old 01-04-2010, 01:47 AM
sounds like it's whatever's going on in the box, software etc. Doesn't sound like a TV problem at all, or cabling.
