HDMI "Y" Connector - 2 Sources into 1 Display? - AVS Forum | Home Theater Discussions And Reviews
Old 01-21-2010, 12:59 PM - Thread Starter
Japsican's Avatar
Hi Everyone,
I have 2 sources (PS3 and Xbox 360) both HDMI. I'd like to run these 2 sources into 1 display. Neither source will ever be turned on at the same time. If I use a HDMI "Y" connector like the one below, would it work for what I'm trying to do?
Marc
Japsican is offline
Old 01-21-2010, 05:04 PM
crutschow's Avatar
I believe that's a passive 1x2 splitter (one source to two displays) which would not work for you.
You need a 2x1 switch such as one of these.
Carl
Curmudgeon Elektroniker
crutschow is offline
Old 01-26-2010, 10:13 AM
vandyhorn's Avatar
I am going to have a projector and a TV in the same room but never use them at the same time (TV during the day, projector at night). I will only have 1 DirectTV box in that room, so it feels like I need what is pictured above. Is that right?
This link goes to one that is only $34. Am I going to lose some signal quality by going through this box?
http://www.monoprice.com/products/pr...t=1#largeimage
vandyhorn is offline
Old 01-26-2010, 11:49 AM
crutschow's Avatar
In theory that should work but the HDMI handshake can sometimes be a problem with these. Try it and, if it doesn't work, return it for a powered splitter.
You will lose no signal quality. HDMI is digital and either works perfectly or very badly.
Carl
