what do you call those plastic cylinders near the connector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-22-2010, 09:59 AM - Thread Starter
LSlugger's Avatar
The 28-gauge HDMI cables at MonoPrice have little plastic cylinders near each connector. Similar Belkin and Blue Jeans cables do not. What are these things called, what is their purpose, and do they indicate anything about the quality of the cable?
LSlugger is offline
post #2 of 6 Old 01-22-2010, 10:05 AM
Japsican's Avatar
Theyre ferrite filters. They filter out EMI/EMF interference. All I use are the monoprice HDMI cables, no reason to waste your money on some "name brand" cable that wont make any difference. I'd rather use a cable with a ferrite filter than one without if I had the option.
Japsican is offline
post #3 of 6 Old 01-22-2010, 01:13 PM
ChrisWiggles's Avatar
ferrite chokes
ChrisWiggles is offline
post #4 of 6 Old 01-22-2010, 01:15 PM
They do not indicate anything about the quality of the cable. They only indicate the presence of a ferrite choke.
You can also just buy a choke and put it on the cable yourself easily if you feel you need that.
The blue jeans is quite superior a cable to the monoprice, stuff, but also more pricey. I have experience with both, and monoprice does make some good stuff too.
post #5 of 6 Old 01-22-2010, 01:22 PM
Colm's Avatar
Liked: 94
Ferrites are put on cables to reduce the amount of eletrical noise radiated into the environment. They also affect the signal that is being transmitted along the cable. If you don't have a reason to reduce the amount of noise your cables are radiating, like they are interfering with the operation of a receiver, it is a good idea to not have ferrites on your cable because they will reduce the performance of the cables.
Colm is offline
post #6 of 6 Old 01-22-2010, 05:07 PM - Thread Starter
LSlugger's Avatar
Thanks, guys. I'm getting much better search results with "ferrite" than I was with "little plastic thingies."
LSlugger is offline
Reply HDMI Q&A - The One Connector World
