Monoprice HDMI Static, Snow, Sparkles, Lines with PS3 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-04-2010, 03:32 PM - Thread Starter
22ryan's Avatar
Just received four 6ft 28awg Monoprice cables with Ferrite cores. I've tried them, one at a time, between my PS3 and my Onkyo receiver and all of them are resulting in sparkles or whatever you want to call them (see picture). Everything works fine when I use a cheap hdmi cable that I got for free with some av device. Anybody have any idea what the problem is? Monoprice cables seem to get good reviews but it seems I might have four bad cables.
22ryan is offline
post #2 of 8 Old 06-04-2010, 06:12 PM
Colm's Avatar
Liked: 94
Why in the world would you buy HDMI cables with ferrite cores on both ends? Ferrites are put on cables to keep the equipment they are connected to from polluting the environment with RFI. They are not good for the HDMI signal.
Colm is offline
post #3 of 8 Old 06-04-2010, 08:45 PM - Thread Starter
22ryan's Avatar
Why in the world would a company make an hdmi cable with ferrite cores if the cores screw up the signal? And why doesn't everyone else have the same problem I do?
22ryan is offline
post #4 of 8 Old 06-04-2010, 08:51 PM
homank76's Avatar
You said cheap cable worked and the monoprice ones do not. What do you call monoprice cables, aren't they cheap?
Panasonic TC-P58S2, Onkyo TX-NR1007, Onkyo DV-SP1000, Onkyo DV-HD805, Onkyo BD-SP807, Onkyo DX-V801, Onkyo UP-A1, Onkyo TA-RW411, Onkyo EQ-201, Yamaha Speakers NS700/750 Series, Blue Jean Cables
homank76 is offline
post #5 of 8 Old 06-04-2010, 09:52 PM - Thread Starter
22ryan's Avatar
I was just trying to imply that it should work even though they are cheap cables. No one has any experience with this problem?
22ryan is offline
post #6 of 8 Old 06-04-2010, 09:52 PM
ChrisWiggles's Avatar
Then use the cheap freebie cables. Apparently there is a problem with these monoprice cables. Try some other cables.
Probably some kind of manufacturing problem, because even at 6ft the crummiest cables should work just fine. You might want to contact monoprice about this specifically since they might want to know that there is an issue.
ChrisWiggles is offline
post #7 of 8 Old 06-04-2010, 09:53 PM
Yes this is a common problem and it indicates insufficient bandwidth on the interconnect. That this appears with such a short cable is unique and rare. But clearly it is a cable problem. Change cables to one with higher bandwidth that eliminates the problem.
post #8 of 8 Old 06-05-2010, 10:53 AM
Colm's Avatar
Liked: 94
Monoprice is an importer and retailer, not a manufacturer. I will give them the benefit of the doubt and guess that they sell them because they don't know any better. Their description of them on their site certainly indicates that. I suspect the manufacturer put them there because they look cool to people who don't know any better.
Most people do not use HDMI cables with ferrites. And my guess is that some of those that do have lower bandwidth requirements than you, and some have exactly the same problem.
Just about any 6' HDMI cable without ferrites should work. Get one tested to Category 2 and you should be pretty sure of success.
Colm is offline
Reply HDMI Q&A - The One Connector World
