HDMI to go by by... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-03-2010, 11:28 AM - Thread Starter
barryecohen's Avatar
Quoted: 21 Post(s)
I just wish they'd done it this way from the start...
http://www.dailytech.com/So+Long+HDM...ticle18902.htm
So much media, so little time...
Oppo BDP-83 > Emotiva UMC-200 > Audio Alchemy OM-150 Dual Mono > Gallo Reference 3.5
_____________________________ > Audio Alchemy OM-150 > Gallo Strada
barryecohen is offline
post #2 of 7 Old 07-04-2010, 12:16 PM
Brent McCall's Avatar
While this is getting a lot of web time there is a large amount of missing info.
#1. This does NOT replace HDMI in the system.
It is placed behind the Tx (source) HDMI board and in front of the RX (display) board. It does not in any way effect how HDMI works.
#2. Cost.
This will add $20+ dollars at build of materials cost per connection (which equates to around $100 by the time it gets to retail).
#3. This will have a huge impact on retailers.
Contrary to popular belief retailers break even at best on hard goods (DVD, Blue-Ray, FPD and gaming systems). Accessories are what allow retailers to sell these items at the price that they do. Without added cable sales retailers will reduce the amount of FPD inventory thus cutting a mfgr's ability to move displays.
#4. To much upfront investment to change.
Equipment mfgr's are just now starting to recoup HDMI R/D costs, they do not want/need another format.
#5. Most important.
The cast majority of consumers have no issue with HDMI as it stands.
They connect a couple of sources to a display with 6' cables and life is good.
The "CI" community is very small and of little effect on the sales bottom line.
Brent McCall
Not A Dealer
Brent McCall is offline
post #3 of 7 Old 07-07-2010, 06:11 PM
crutschow's Avatar
On what do you base that cost? I don't see that a CAT5 line driver should be any more expensive than an HDMI line driver if incorporated into the system. They are both essentially the same signal, just going over different wires.
Carl
Curmudgeon Elektroniker
crutschow is offline
post #4 of 7 Old 07-07-2010, 07:00 PM
Colm's Avatar
Liked: 94
My guess is you will see this technology primarily on TVs and AVRs, perhaps just adopting manufacturers' higher end ones initially, to solve the problem that HDMI has with long distances between the source and the display. There is really no need for the individual sources to incorporate this technology. They are typically close enough to the AVR that HDMI works fine. And for those than don't have an AVR with the capability, a switch with this technology can be used just like folks use HDMI switches now. I don't think in any way it is going to supplant HDMI in most products.
Colm is offline
post #5 of 7 Old 07-07-2010, 08:35 PM
This is not a network type chip it is a Pan5 chip multi-layer/multi-voltage (whole different animal) then of course like HDMI there is only one vendor for the technology.
Also do not forget that HDMI is still in the source/display device, but now it would have this chip-set and an emulator added.
We looked into this two years ago (this is not really new) and at that time to create a point to point transmission system we would have had to retail it at $1200.00 which put it into fiber territory.
The original product developing company (not the technology creator) went out of business maybe Valens will have better luck (but, I do not think so as big box retailers have NO incentive to support this format).
Brent McCall
Not A Dealer
post #6 of 7 Old 07-08-2010, 02:40 PM
RioTubes's Avatar
sorry for the rudimentary question but will existing TVs with ethernet ports (i.e. Panny TV to receive viera cast) and Dish DVR boxes be able to transmit and receive HDBaseT through existing ethernet ports on those boxes? Or does the HDBaseT protocol require different transmission and receiver hardware in the source (blu ray, DVR, etc.) and TVs themselves?
Ahh just found the answer and, yes, there will be HDBaseT chipsets required...I guess maybe they'll offer a dongle or other means of conversion.
RioTubes is offline
post #7 of 7 Old 07-08-2010, 03:42 PM
No.
HDBaseT is an IP standards beased system.
Brent McCall
Not A Dealer
Reply HDMI Q&A - The One Connector World
