How to check if my HDMI cable is 1.3 compliant? - AVS Forum | Home Theater Discussions And Reviews
Old 07-17-2010, 04:45 AM - Thread Starter
finaltidus's Avatar
Anyway to check? I don see any prints on the cable that state the status of the cable.
Any tests I can do to verify it?
finaltidus is offline
Old 07-17-2010, 10:35 AM
Colm's Avatar
Liked: 94
The only way to test it is to send it to a testing lab unless you want to spend a whole lot of money on equipment. Even that would cost more than a new cable.
Colm is offline
Old 07-17-2010, 11:09 AM
crutschow's Avatar
The only designation that counts for HDMI cable is standard speed and high speed.
But just plug the cable in. If it works then it's compliant to your requirements.
Carl
Curmudgeon Elektroniker
crutschow is offline
Old 07-17-2010, 12:00 PM
Colm's Avatar
Liked: 94
For now...
There is no guarantee that it will continue to be...
FWIW if you don't see sparkles or worse, it is already as good as it gets.
Colm is offline
Old 07-21-2010, 10:03 AM
KurtBJC's Avatar
The best way to verify compliance is to get your supplier to send you a copy of his compliance certificate. If he has a pre-1.3 certificate for a length at least as long as your cable, the cable is 1.4 compliant as a "standard" HDMI cable. If he has a 1.3 certificate or 1.4 certificate indicating "Category 2" or "High Speed," then it's 1.4 compliant as a "high-speed" cable.
Kurt
Blue Jeans Cable
KurtBJC is offline
