Image cycles dark and light - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-09-2010, 02:35 AM - Thread Starter
jwdenning's Avatar
I just moved my HT around where I'm now using a 25' hdmi cable to the Samsung 55" LED TV from a Yamaha RX-V667 receiver. Watching DVD or Apple TV the image cycles between a good bright image and a dark image.
Is this the cable? When connected with the same brand of 2M cable it looked great.
-JD-
jwdenning is offline
post #2 of 9 Old 11-09-2010, 11:19 AM
Paladin68's Avatar
With the information given, I would suspect the cable. I have seen many issues with HDMI cables but not that exact symptom. Have you had the 25 foot cable a while? Hdmi at 15 feet and under does not have issues a 25 footer might exhibit and the fact you swapped it and removed the problem is a good indicator.
Paladin68 is offline
post #3 of 9 Old 11-09-2010, 11:49 AM - Thread Starter
jwdenning's Avatar
Cable brand new. I've got another cable, different make coming, one that says HDMI 1.3. I also plugged it into a different port on the TV, but haven't had a chance to test that.
This was a hard one to describe I'll report back once I try another cable.
-JD-
post #4 of 9 Old 11-09-2010, 11:53 AM
mgkdragn's Avatar
Quoted: 1717 Post(s)
Liked: 1997
Complete info on model of TV .. ?? Any source working properly, such as cable ..?? Anything is possible, however, it's unlikely to be the fault of your HDMI cable ..
Uncle Willie
Oddball: Why don't you knock it off with them negative waves? Why don't you dig how beautiful it is out here? Why don't you say something righteous and hopeful for a change?
mgkdragn is offline
post #5 of 9 Old 11-09-2010, 02:13 PM
Paladin68's Avatar
I believe the questioner tried it with a two meter hdmi and the picture was fine. Two sources showed the same symptom according to his statement I believe also, but then perhaps I misread.
post #6 of 9 Old 11-10-2010, 07:48 AM
mgkdragn's Avatar
Liked: 1997
Sorry, but I've never heard of an HDMI cable causing light pulsing ..
Uncle Willie
mgkdragn is offline
post #7 of 9 Old 11-10-2010, 09:58 AM - Thread Starter
jwdenning's Avatar
The TV is a Samsung UN55C6500 Receiver is a Yamaha RX-V667. I've had them about 1.5 months. Was using a 2M HDMI. No problems, beautiful image. All I did was move things around, so am now using a 25' cable and anything from the receiver looks poor. Cable still looks good, as good as it can
I have a new cable coming, should have it soon. Maybe defective??? And yes from what I've been reading it is almost unknown.
-JD-
post #8 of 9 Old 11-10-2010, 02:04 PM
Paladin68's Avatar
Yeah, I kind of said that earlier myself but you can get into issues with longer cables at times and with a two meter cable working fine, trying another brand of 25 foot seems logical. We should have an answer fairly soon regardless.
post #9 of 9 Old 11-17-2010, 11:36 AM - Thread Starter
jwdenning's Avatar
Well new cable looks good. I don't know if this matters, but the old cable was difficult to plug in. Real tight space since it goes in sideways. It could have been not pushed in all the way.
Though like I said Cable looked good, just optical disks that didn't. Looked like old Macrovision .
But it's happy now. Got it all connected, calibrated, working and love it. Had to get a 25' optical cable for audio from TV to 667. No problem there at all.
Now I just need to program my universal remote app for the iPhone.
Thanks everyone...
-JD-
Reply HDMI Q&A - The One Connector World
