Optical cable needed for sound with HDMI? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-15-2010, 09:58 PM - Thread Starter
aclumpkin's Avatar
I just purchased a Pioneer Elite SC-37 with HDMI 1.4a switching (haven't set it up yet though). I am upgrading from an old Arcam receiver that does not have HDMI switching. Therefore, I am used to running HDMI cables directly from my sources (such as my Blu-ray player) to the HDTV for video and then separate optical cables to the Arcam for the sound. Now that I have the HDMI switching on the SC-37, do I need the optical cables anymore?
I know that technically HDMI cables do carry digital sound on them but I am curious if there is anything to gain in connecting dedicated optical cables to the SC-37 to handle the sound for my sources. Is this overkill / not needed? Or is there an advantage to keeping the optical cables?
Note that I have already purchased and upgraded my HDMI cables to 1.4 high speed, category 2 + ethernet, audio return channel cables.
Thanks in advance for the help and guidance!
aclumpkin is offline
post #2 of 4 Old 11-16-2010, 06:24 AM
ccotenj's Avatar
Liked: 101
nope, no need for the optical cables...
nope, nothing to gain by keeping them...
- chris
ccotenj is offline
post #3 of 4 Old 11-16-2010, 08:36 AM
crutschow's Avatar
You need HDMI to get uncompressed audio from a Blu-Ray player, which optical cables can not carry.
Carl
Curmudgeon Elektroniker
crutschow is offline
post #4 of 4 Old 11-16-2010, 10:10 AM - Thread Starter
aclumpkin's Avatar
Thanks!!!
Reply HDMI Q&A - The One Connector World
