HDMI Image Flicker - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-01-2010, 02:09 AM - Thread Starter
mgouin's Avatar
Hi all,
I have simple setup. HD receiver (Scientific Atlanta 4250HD) hooked up to my HDTV (Sony KDL-46V5100) using a 6-feet HDMI cable from monoprice.
Here's my problem. In HD channels, I see very annoying image flickers. They happen at various rate (from every 30 second to every 5 minutes). I noticed they are more frequent in fast action scene (ex: hockey, football games). I saw two types of flickering:
1. The whole image seems to freeze for a few milliseconds, then resume.
2. Only a small part of the image gets distorted or change color. It's mostly a rectangular region that changes to black or white.
I already tried with another HDMI cable more expensive than the monoprice cable (not a monster cable tough) with no significant changes. I also tried all 4 HDMI input ports of my TV with no success. I called the cable company (videotron) many times. They boosted the signal level so the debug pages on the receiver displays acceptable signal level. They also replaced the receiver with another one. With the component cables, the flicker does not happen.
Could my replaced receiver was still defective? Could it be my TV that has a problem with HDMI? Have you experienced this problem? Is there any other tests I could try?
Thank you very much in advance for your help!
Mathieu
mgouin is offline
post #2 of 3 Old 12-01-2010, 09:25 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 240 Post(s)
Liked: 3437
Try using a Blu-ray player with the TV or a DVD player that can output 1080p60. That will push the most amount of data you'll need (sans 3D) to see if the TV has issues. Most likely it's a cable TV infrastructure issue or the HD box itself, and possibly a source issue. What output resolution are you setting on the "box" with HDMI and component output?
larry
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
post #3 of 3 Old 12-01-2010, 10:06 PM - Thread Starter
mgouin's Avatar
Hi Larry,
Thanks for the reply.
I forgot to say in my original description that I already tried with a friend's blu-ray and did not see any flicker.
I don't understand what you mean by:
...and possibly a source issue
Do you mean there could be a problem in the program itself being broadcasted (through coax cable)?
With both HDMI and component output, I set the resolution to 1080i (the max that my "box" can output. It is also confirmed by the TV (there is a function to tell the current input format). But the blu-ray was outputting at 1080p.
Mathieu
mgouin is offline
Reply HDMI Q&A - The One Connector World
