Amazon Basics HDMI cables? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-15-2011, 11:59 AM - Thread Starter
MceeGs's Avatar
I was checking out the Amazon Basics HDMI cables and noticed that they do not say what gauge they are. Does anyone know? Are they 24AWG, 26AWG, or 28AWG?
MceeGs is offline
post #2 of 6 Old 02-15-2011, 12:23 PM
Colm's Avatar
Liked: 94
Is there a reason you care? They all claim to be high speed HDMI cables.
Colm is offline
post #3 of 6 Old 02-15-2011, 05:51 PM - Thread Starter
MceeGs's Avatar
The thicker the guage the better protection from interference but the stiffer the cable. Just like to know exactly what I'm buying ahead of time.
MceeGs is offline
post #4 of 6 Old 02-15-2011, 07:11 PM
Colm's Avatar
Liked: 94
Wire gauge doesn't have a significant effect on interference, just attenuation. It is relevant for longer cables.
My guess is the Amazon cables are made with the smallest wire that will allow the cable to pass the HDMI high speed certification test. There is really no need for larger than that.
Colm is offline
post #5 of 6 Old 02-16-2011, 10:03 AM - Thread Starter
MceeGs's Avatar
You don't happen to know what guage that would be do you. I actually do need a longer run so now I really would like to know.
Has anyone out there bought Amazon Basic cables yet that knows what the guage is?
MceeGs is offline
post #6 of 6 Old 02-16-2011, 02:24 PM
Colm's Avatar
Liked: 94
Smallest gauge typically used is 28 AWG. How long a cable do you need?
Colm is offline
Reply HDMI Q&A - The One Connector World
