HDMI Audio Converter? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-21-2011, 08:00 AM - Thread Starter
destropaul's Avatar
Anyone know of a product that will convert HDMI with surround audio to: HDMI output with 2-channel audio? This "converter" must have one HDMI in and one HDMI out ONLY (plus power).
We're going from the 4th output on a matrix switch to a four-way splitter out to four TVs. The first three outputs on the matrix switch are going to surround receivers.
Any ideas??
destropaul is offline
post #2 of 7 Old 02-21-2011, 10:37 AM
alk3997's Avatar
Liked: 92
Any ideas??
Add a cheap pre-amp that can convert surround to 2-channel. Cheapest way I found.
Also, you might try Optava - they have a switcher which will convert to RCA and I think Toslink.
alk3997 is offline
post #3 of 7 Old 02-25-2011, 06:12 PM
Michael@Atlona's Avatar
Try out the Atlona AT-HD570, it will be able to do what you are looking for!
Michael@Atlona is offline
post #4 of 7 Old 10-29-2011, 12:57 AM
ciarra's Avatar
I search on the net and i didn't found so many things. i think Atlona AT-HD570 is gonna be good i read some reviews bout it. so it can help you.
ciarra is offline
post #5 of 7 Old 10-29-2011, 09:28 AM
DrDSL's Avatar
As I understand the OP, he was looking for a device that was HDMI in and HDMI out that would convert the digital multichannel in to a 2 channel digital out in the HDMI stream. As I understand the AT-HD570 it will extract the audio streams form the HDMI input and convert them to analog format or present them in digital format to a optical output. I was not aware that the device could re-insert the down mixed audio in the HDMI output stream.
Does anyone know if it can actually do this?
DrDSL is offline
post #6 of 7 Old 10-29-2011, 10:21 AM
alk3997's Avatar
Liked: 92
We looked a while back for someone and we could not find an audio injector for HDMI. Only way I can think to do this is to then decode the video, recombine the audio and then get a converter to go back to HDMI. There are also HDMI license holder issues with the "decode the video" part.
alk3997 is offline
post #7 of 7 Old 11-02-2011, 02:59 PM
Joe Fernand's Avatar
Quoted: 285 Post(s)
Liked: 167
Replace the TV in the 'non-AVR' Zone with a model that includes SRS HD support.
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is online now
Reply HDMI Q&A - The One Connector World
