HDMI 1.4 can't do 1080p@120hz? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-23-2011, 11:58 AM - Thread Starter
Tyrindor's Avatar
Quoted: 1317 Post(s)
Liked: 651
Someone want to tell me why? It clearly has the supported bandwidth.
I've done a lot of reading and can't figure it out. My New 3DTV was suppose to be connected to my computer and run 1080p @ 120hz, however I now come to find that HDMI 1.4 can't support it and you need DVI-D (which no TV on the market has).
Tyrindor is offline
post #2 of 4 Old 03-23-2011, 12:09 PM
alk3997's Avatar
Liked: 92
That is correct it cannot. HDMI chipsets cannot support 1080p/120 bitrate (probably the required encryption doesn't help either). That is why Blu-Ray 3D is limited to 1080p/24 (really 48 with both eyes).
alk3997 is offline
post #3 of 4 Old 03-23-2011, 01:32 PM
Colm's Avatar
Liked: 94
...HDMI 1.4 can't support it...
The maximum supported bit rate has been sufficient since the HDMI 1.3 spec. Like Andy said, the electronics in the equipment don't support it.
FWIW if you see 120 Hz in the specs for a TV, it probably is referring to the refresh rate of the screen, not the frame rate of the source material. They are two different things.
Why do you need 120 Hz frame rate?
Colm is offline
post #4 of 4 Old 03-23-2011, 01:41 PM
alk3997's Avatar
Liked: 92
It's must be for 3D gaming. Try this link to a 120Hz input Asus monitor...
http://www.anandtech.com/show/3842/a...ook-at-120hz/2
alk3997 is offline
Reply HDMI Q&A - The One Connector World
