HDMI Extender Issue, RJ-45 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-17-2011, 07:54 PM - Thread Starter
jranch's Avatar
I recently pre-wired my home for two hdmi extenders that use two Cat5e cables a piece to extend the inputs to my amp. The first hdmi extender works fine, but when I hooked up my Cat5 tester the other pair of Cat5's pin number 6 shows no connectivity. I replaced the RJ 45's at each end of the cable and tested them independent of any other component that could fail other than the cable. Needless to say, that HDMI extender will not work. I pulled the extender apart and it appears to use every pin from both Cat5's on the attached circuit board. The Cat 5's are in a location that is not easy to access, which is why I pre-wired them. Anyone have any suggestions on trouble shooting this? Like with 802.3, are their pins in the extenders that don't get used that I can swap no 6 with? Any help would be great. The extender I am using is a Monoprice unit Product ID: 6532. Sorry, I would post a link but AVS doesn't think I am cool enough yet. (I dont have 3 points.)
jranch is offline
post #2 of 5 Old 06-17-2011, 09:27 PM
Colm's Avatar
Liked: 94
Originally Posted by jranch View Post
...are their pins in the extenders that don't get used that I can swap no 6 with?
No, AFAIK there aren't any spare pairs left. There are extenders that use only a single cable, though.
FWIW unless the cable was damaged during installation or later construction, the cable itself is likely not the culprit. It is more likely a termination problem.
Colm is offline
post #3 of 5 Old 06-17-2011, 09:43 PM
Joe Fernand's Avatar
Quoted: 288 Post(s)
Liked: 167
Some Dual wire Extenders will have a 'spare' pair - usually on the cable that carries the DDC rather than the cable carrying the Video signal.
As previously suggested a Single wire solution is a good option - units based around the HDBaseT chip set are rock solid - though costly!
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is offline
post #4 of 5 Old 06-17-2011, 10:55 PM
Colm's Avatar
Liked: 94
Originally Posted by Joe Fernand View Post
Some Dual wire Extenders will have a 'spare' pair...
Which ones Joe? Haven't noticed any yet, but I sure haven't seen every product.
Colm is offline
post #5 of 5 Old 06-18-2011, 04:58 AM
Quoted: 288 Post(s)
Liked: 167
A fair few of the designs not carrying IR and or Optical will have a Spare pair in one of the cables.
I've seen folk use those pairs to carry power or IR from external devices.
Joe
Reply HDMI Q&A - The One Connector World
