100 foot HDMI Cable - AVS Forum | Home Theater Discussions And Reviews
Old 06-22-2011, 04:27 PM - Thread Starter
Laika's Avatar
Quoted: 31 Post(s)
Desktop in other room, Wireless Keyboard and Mouse work from my Home Theater room, would like to run a 100 foot HDMI cable to the TV.
I will move the computer for a short time and check the TV with a short HDMI first to make sure it works. My goal is not to stream but to use it as a computer screen as I listen to CDs and do legal work.
No problem with ratio, refresh rates, will check for overscan when I move the computer in the HT room for a test to see if it will even work.
Likely need a repeater and 75- 100 foot of HDMI, reviews on Amazon are very mixed about what long cables work well and what do not.
QUESTION: Anyone doing this at 75 foot plus and if so and it works well name brand of cable, model, etc.
Want to keep the cost down but if I have to I would likely go up to $150-$200 (Would rather spend around $100.00) and us the extra money to update the real joy, the Audio and Video ends of the Home theater, no just a second work station. Above $200.00 and I will just go in the next room and use the computer and crank the CD's up but I lose the sweet spot.
Laika is offline
Old 06-22-2011, 05:06 PM
Supermatch's Avatar
If using a repeater, should you not be looking at 50 foot cables in lieu of 75 footers?
I will say this much - at 50 feet, there are only two cables that I can personally attest to working reliably: the Monoprice 2678 (22 awg silver plated 50'), and the Blue Jeans Belden Series 1. The Belden's a great value, the Monoprice an outrageous value.
Supermatch is offline
Old 06-22-2011, 05:41 PM
alk3997's Avatar
Liked: 92
Other current threads in this forum are discussing this same issue. You might want to get some expert opinions from those threads.
I can add this, the lower the bandwidth of the HDMI transmissions, the better chance you have of getting a signal. In other words, 1080i and 720p have a better chance of working than 1080p/60.
Also, please keep in mind that even 50 foot of HDMI cable is outside of the HDMI spec. Doesn't mean it won't work, but it means there is a chance it won't work.
Going with a higher gauge cable will help. ALso I'm assuming Supermatch meant "outrageous value" in a very positive way for Monoprice. Their cables have all been reliable for my uses.
alk3997 is offline
Old 06-22-2011, 05:48 PM
Supermatch's Avatar
Correct, I was implying that the Monoprice cable is veeeery tough to beat for the money.
Old 06-22-2011, 05:53 PM
Colm's Avatar
Liked: 94
And the BJC Series 1 is tough to beat at any price...
Colm is offline
Old 06-22-2011, 05:54 PM - Thread Starter
Laika's Avatar
Quoted: 31 Post(s)
My problem is it's over a 50 foot run, I need to measure but I am in the 75' range at least as I have to go up and down then run the span of a room and a half, thanks though, I will measure and look into the cables you suggest.
Laika is offline
Old 06-22-2011, 06:02 PM - Thread Starter
Laika's Avatar
Quoted: 31 Post(s)
I will be running at the same rate as the computer monitor as I am told that will not tax the system with to resolutions as the HDMI auto puts out what the monitor is set for 1920 x 1080, thanks for the cable advice.
And if I am missing something where the HDMI can go a lower res without taxing the system, which is a workhorse, then I do not mind dumbing it down as I don't stream but use a stand alone WD-TV with HD's connected.
I just don't want to sink alot into this because it's just not worth it to me, $4000 on s sub, perhaps worth it, $200.00 on second video card and ad cable, not worth it.
I'm thinking repeaters should work on the length but I know Home theater but not PC to HD TV so I clearly might be wrong.
Any chance you could could point me to one of these threads, all I saw was 50' runs but did not read past the thread title.
Laika is offline
Old 06-22-2011, 06:07 PM - Thread Starter
Laika's Avatar
Quoted: 31 Post(s)
My guess was wrong from running so much speaker cable years ago, 50' may do it, very close but I think I can force it, 60 foot would be perfect.
Laika is offline
Old 06-22-2011, 06:39 PM
alk3997's Avatar
Liked: 92
Yes, standard speeds for HDMI are used at 1080i / 720p which were the standard resolutions before 1080p came along into the spec.
If I were you, I'd try a really good cable first - you've gotten some good recommendations. If the cable doesn't work, any other solution I can think of will cost you over $200 except for using less bandwidth.
alk3997 is offline
Old 06-22-2011, 07:49 PM - Thread Starter
Laika's Avatar
Quoted: 31 Post(s)
Thanks, I am going to run string and see how short I can go, follow the recommendations and make sure get a fairly high end one I can return.
Laika is offline
Old 06-23-2011, 01:36 AM
Joe Fernand's Avatar
Quoted: 282 Post(s)
Liked: 166
Running a piece of string and running a 22AWG HDMI cable are very different matters - the HDMI cable is not flexible and won't go around tight corners; you can force them but eventually they tend to fail.
We see a lot of folk who have run long HDMI cables have in-life' problems with failing connectors - often damaged when folk are moving kit around for cleaning or kit upgrades.
Far more practical/likely to work if you install 2 x UTP, Solid Core CAT6 cables and add in a suitable set of HDMI over Twisted Pair Extenders - for 199 USD you can have a high quality set of Extenders that also offer an IR return path to your Source kit.
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is offline
Old 06-23-2011, 09:41 AM
alk3997's Avatar
Liked: 92
Joe
Joe, could you provide a brand/model for these? I'd like to add these to my list of potential solutions.
alk3997 is offline
Old 06-23-2011, 12:32 PM - Thread Starter
Laika's Avatar
Quoted: 31 Post(s)
Thanks, I second that, I'm a bit lost past the CAT 6, if it's a DYI that needs to be built perhaps a link to a schematic.
Thanks for the tip on the solid Cat 6, I was way wrong, did the string thing last night and am at 40 feet so I can do a gradual 90 with room to spare, in the past on such things I go get a PVC 3/4 inch conduit elbow and run a cable through there, nice 12 inch gradual bend, normally works well just hanging it around the bend but with the suspended ceiling I can mount it with a few conduit straps than put the panels back in to hid it.
Laika is offline
Old 06-23-2011, 04:40 PM
Quoted: 282 Post(s)
Liked: 166
Look for Octava Inc. - three options. HDMI + IR (dual CAT6), HDMI + IR + Optical ( dual CAT6) and HDMI + IR ( single CAT6 using HDBaseT). The 'Optical' unit can send or Receive IR and Optical to or from the remote zone - you set them up independently using Dip switches.
Joe
Old 06-23-2011, 06:00 PM
alk3997's Avatar
Liked: 92
Joe
Thanks - I should have looked a bit deeper (past the matrix switchers) on their web site.
http://www.octavainc.com/HDMI%20ethe...onverters.html
The final cost will actually be slightly above $200 when shipping and the two cables are included. But, at least Octava includes *both* power supplies so 120' is possible at 1080p/60 (or 3D).
alk3997 is offline
