HDMI and 3D - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-23-2011, 03:18 PM - Thread Starter
Sabin057's Avatar
Hello all,
I am planning to get a "high speed" hdmi. I was just wondering if the AWG makes any different with 3D content. I'm guess guess "no," but haven't see anything specifically about 3D.
Considering 28 and 24 AWG @ monoprice. 24 AWG is twice the price of 28 - but 28 AWG comes with those ferit cores... I remember those putting stress on the HDMI port of my old Onkyo rc-120.
PS- Monoprice seems to have two of the same 28 AWG HDMI cable... but one is ~$3.50 and one is ~$2.50. Anyone know if there is a difference of some sort, because I looked through all of the description and didn't find anything.
ÂIt's the job that's never started as takes longest to finish. ― J.R.R. Tolkien, The Lord of the Rings
Sabin057 is offline
post #2 of 4 Old 11-23-2011, 03:48 PM
Colm's Avatar
Liked: 94
A high speed cable is capable of handling any HDMI signal. All other things being equal, a cable with larger wire should be able to perform adequately at a longer length, at least to some degree.
Colm is offline
post #3 of 4 Old 11-23-2011, 07:39 PM - Thread Starter
Sabin057's Avatar
Ah ok. Thank you. So I'll go out on a limb and say that both should work equally well at 6'.
Sabin
Sabin057 is offline
post #4 of 4 Old 11-23-2011, 09:06 PM
Colm's Avatar
Liked: 94
Originally Posted by Sabin057 View Post
...I'll go out on a limb and say that both should work equally well at 6'.
Almost anything will work well at 6'.
Colm is offline
Reply HDMI Q&A - The One Connector World
