How do I get audio using a DVI cable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-10-2011, 09:42 PM - Thread Starter
Villagepeople's Avatar
I have my computer connected to my HDTV through a DVI cable. Obviously I don't have audio, and I want my TV to output the audio! I read that with a toslink cable that is possible, but the problem is that I do not have a toslink port in my CPU, just on my HDTV.
Well, What could I do about this?
This is my computer rear:
and my HDTV rear:
side view(just in case):
Please help me, I would like to have the best audio possible on my HDTV, thanks!
Villagepeople is offline
post #2 of 2 Old 12-11-2011, 03:04 AM
Joe Fernand's Avatar
Quoted: 288 Post(s)
Liked: 168
A 3.5m Stereo jack to 2RCA cable from the PC 'Line Out' (Lime) to the DVI Audio input on the TV is what you require!
Joe
PS and get the vacuum out before you start plugging in cables - its pretty grotty around the back of your TV, if your PC is close by it likely needs to be de-clogged too before it starts to overheat!
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is offline
Reply HDMI Q&A - The One Connector World
