Please recommend 50ft HDMI high speed (3D compatible) cable with ARC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-22-2011, 09:24 AM - Thread Starter
Morhpeus's Avatar
I have to buy a 50ft HDMI high speed (ver 1.4, 3D compatible) cable with ARC. It should be rated for in-wall installation.
I'm looking for recommendations. Hopefully, it should be able to transmit 1080p and not just 1080i.
Morhpeus is offline
post #2 of 2 Old 12-22-2011, 02:59 PM
Colm's Avatar
Liked: 94
All HDMI cables support ARC. However, there is no such thing as a passive 50' High Speed HDMI cable. Longest certified High Speed HDMI cable is about 25'. That doesn't necessarily mean a longer cable won't work for you, just that the cable won't be full bandwidth. 1080p60 is quite doable at that length. So is 1080p24 3D. If you need the full bandwidth for something like 1080p60 3D or DeepColor, you will need a certified active High Speed HDMI cable, or a media adapter that supports the desired bandwidth. Best bet is an HDBaseT based solution.
Colm is offline
Reply HDMI Q&A - The One Connector World
