HDMI Matrix Switch - Why is this so complicated???? - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #151 of 153 Old 03-21-2016, 04:38 PM
audvid's Avatar
Quoted: 348 Post(s)
Liked: 94
Originally Posted by mariokrt64 View Post
I have a similar issue...one of the outputs from my Onkyo receiver feeds my Panasonic ST60 Plasma (a 3DTV) and the other Onkyo output I want to split/switch between a JVC 2D Projector and an Epson 3D Projector....got a "3D" capable splitter on Amazon but did not pass the 3D signal.
I am no expert on the EDID signal but if you want to switch, the switch i mentioned about, should work just fine. If you want to split - some times there is a problem. I don't recall but I think the switch I use works even for split. It works just fine as a switch.. I have been using it for several years, with no problem.
I think I posted info about it in prior posts. It is a generic 4X2 matrix switch for about $100 or so..
audvid is offline
post #152 of 153 Old 03-21-2016, 04:57 PM
mariokrt64's Avatar
Quoted: 34 Post(s)
You meant switch to two type of different displays, one 3D other 2D?
mariokrt64 is offline
post #153 of 153 Old 03-21-2016, 05:25 PM
audvid's Avatar
Quoted: 348 Post(s)
Liked: 94
I meant.. the source (BD Player) will need EDID authentication. I am not sure how the authentication is handled when two devices are connected simultenously.. but obviously, we have seen multiple TVS working on same signal. I think my own switch also works fine when two devices are connected to the same source. Some times, I might have to switch between sources to make it work.. Over all, the hdmi matrix switch seems to work just fine..
audvid is offline
Reply HDMI Q&A - The One Connector World
