The Unoffical source for everything HDBaseT - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #271 of 291 Old 02-18-2016, 12:38 PM
cdika17's Avatar
Any options for a 4x4 or 8x8 hdbaset matrix extender package that isn't a billion dollars and affordable for us Canucks up north of the border, silly Canadian economy.
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #272 of 291 Old 02-18-2016, 12:58 PM
Joe Fernand's Avatar
Quoted: 406 Post(s)
Liked: 225
4x4 pricing is very different to 8x8 pricing and no matter where you live everyone complains that HDBT is too expensive!
Joe
Octava Inc. Multi-cast HD over LAN solutions.
Ruipro UK and EU Sales and Support
The Media Factory. Residential and Commercial system Design, Consultancy, Installation, Supply and Integration.
Joe Fernand is online now
post #273 of 291 Old 02-23-2016, 12:45 PM
john stephens's Avatar
Quoted: 39 Post(s)
Liked: 40
How to fix a Monoprice 4 by 4 HDBaseT Matrix
The symptoms were that one of the channels no longer displayed the digital signal. St first I thought that the matrix itself had failed but to my glee, the problem was on the receiver end. And at that, it was merely that the external 5V/2 Amp power supply had failed. Out of all the potentially dreadful causes, this was by far the simplest and cheapest to fix. Indeed, Amazon sells an equivalent 5V supply for just $8.99. I bought one of these, whereupon the RX began working again. Since then, another channel failed, this time I just ordered another supply and the problem was fixed. In anticipation that this supply is a dominant cause of failures, I went ahead about two additional supplies and swapped them for the originals units. To sum up, for less than $40, I removed the Achilles heel of this system.
This all makes sense, since the innards of these units are based on Valens chips and layouts etc., similar to that of much m ore expensive brands. The robustness of the Valens chip/architecture is well known. I think these units inherit that as well.
So if you have a similar problem in the future, don't bother to call Support, just swap out that DC supply. Enjoy!
john stephens is offline
post #274 of 291 Old 03-25-2016, 11:36 PM
Old Soul
APRisti's Avatar
Quoted: 68 Post(s)
Liked: 8
Which of these wires do you guys suggest I install for the HDBASET run
Blue
http://pr.blackbox.com/Store/Detail..../EYN911MS-0050
Purple
http://pr.blackbox.com/Store/Detail..../EVNSL648-0050
APRisti is offline
post #275 of 291 Old 03-26-2016, 04:32 AM
Quoted: 406 Post(s)
Liked: 225
Either or will likely do - we use the GigaTrue on all of the installs where we get to choose the cables.
Joe
post #276 of 291 Old 06-20-2016, 08:20 PM
Welshdog's Avatar
Extender with HDMI splitter on transmitter?
I'm looking for an HDMI extender that has a pass-through or splitter on the transmitter. The situation here is that I have a Tivo that feeds into a Denon receiver. I want to send that Tivo HDMI output to a TV in the kitchen and to the Denon receiver simultaneously. I can probably manage to get a CAT5 to the kitchen, but not an HDMI cable.
I'm pretty sure there was a device that had this feature a couple of years ago, but I can't seem to find any now. Has anyone ever seen an extender that has this feature?
"Nobody looks good in high-def"
Doug Wilson - Weeds
Welshdog is offline
post #277 of 291 Old 06-21-2016, 12:51 AM
Quoted: 406 Post(s)
Liked: 225
We would normally supply/install a 1x2 Splitter plus an HDBT Extender.
Keep in mind if the kitchen TV only supports Stereo audio you will need to set the Source to HD Video + Stereo audio via HDMI plus 5.1 via Optical and connect an Optical between the Source and the AVR and configure the AVR to use the Optical audio.
Use Solid core, non-CCA, UTP CAT6 for the extender.
Joe
post #278 of 291 Old 06-21-2016, 11:06 PM
Welshdog's Avatar
Joe
Thank you.
I had thought of doing that, but was concerned it might create issues. Is it okay to use a couple of really short HDMI cables in patching this up?
Doug Wilson - Weeds
Welshdog is offline
post #279 of 291 Old 06-22-2016, 12:04 AM
Quoted: 406 Post(s)
Liked: 225
Keep in mind HDMI plugs are relatively long so either use very flexible short cables or a slightly longer than you had planned cable.
We use plenty of 0.5m and 1.0m HDMI cables.
Joe
post #280 of 291 Old 06-24-2016, 12:18 PM
spencers's Avatar
Trying to find some information on HDBaseT for a particular use case and I cannot find any information anywhere.
I have a gaming PC in a networking closet and a desk/monitor in the office ~25 ft away. I am looking for a HDBaseT adapter that will transmit 2560x1440 at 60hz to my monitor. I can't find any adapters that specifically mention this resolution. It's either 1080p or 4k with nothing in-between. Am I out of luck?
spencers is offline
post #281 of 291 Old 08-03-2016, 08:55 AM
wingm8's Avatar
Monoprice has a new line of HDBaseT devices called Blackbird: (Monoprice product Link)
Here's the description for PID 15777:
The Monoprice Blackbird™ 4K HDBaseT™ HDMI® Extender Kit with PoC is a tool which can extend your HDMI video and audio signal up to 330 feet to an HDMI equipped projector or display. Our Blackbird 4K Extender with PoC is designed to convert an HDMI signal to standard HDBaseT signal, which then can be transmitted by a single Ethernet cable. The Blackbird 4K HDMI Extender with PoC supports all the latest compliance, including HDMI 2.0, HDCP 2.2 and HDBaseT 2.0.
Features:
  • One pair as a full functional module, no need for setting
  • Use single UTP/STP LAN cable (CAT-5e/6) to substitute HDMI cable to achieve long distance transmission
  • UTP/STP cable termination follows the standard of IEEE TIA-568B
  • Transmission distance reaches up to 100 meters for 1080p and up to 70 meters for 4K video
  • POC (RX powered by TX)
  • HDCP 2.2/1.4 compliant
  • Full HD support: 1080p@60Hz@48bits/pixel, 3D, and 4K
  • LED indicators show the power status
  • Built-in ESD protection
  • Includes mounting ears
  • Transfers bidirectional infrared control signals together with the HDMI signal
  • Phoenix RS232 port for firmware update or RS232 control signals
I asked customer service for more information:
[11:31 AM] Robert H.: For the new HdbaseT units, it would support full 4k meaning 4k at 60Hz at 4:4:4
[11:32 AM] Robert H.: This would support the full 18 Gbps.
wingm8 is offline
post #282 of 291 Old 08-04-2016, 09:55 AM
Philip Klein's Avatar
Blackbird™ 4k HDBaseT vs. HDBaseT 2.0
Seems to be toward 2.0 but not all the features. Any affordable HDBaseT 2.0 switchers out there?
- Phil
Philip Klein is offline
post #283 of 291 Old 11-12-2016, 09:42 PM
carealtor's Avatar
All sources in the same place?
It looks to me, in order for this to work, all of the source components have to be in the same place, such as the equipment closet. I can put all the Uverse STBs in the equipment closet along with a matrix switcher, but the Blu Ray player has to stay in the theater. How do I get the Blu Ray player HDMI to the equipment closet?
carealtor is offline
post #284 of 291 Old 11-13-2016, 06:14 AM
Postmoderndesign's Avatar
Quoted: 328 Post(s)
Liked: 149
IMHO disc players need to be local at the present time if just for the convenience of changing discs. Ripping UHD discs to network storage, if and when that becomes possible, is a useful method of having movies available throughout the house.
The HD over LAN rather then HDBaseT could make sources available to all displays. I don't know if that is a practical solution and you still would have the disc changing issue as well as compression-decompression artifacts.
Anál nathrach, orth’ bháis’s bethad, do chél dénmha
Postmoderndesign is offline
post #285 of 291 Old 11-13-2016, 09:57 AM
Quoted: 406 Post(s)
Liked: 225
There are one or two HDBT Matrix with HDBT Inputs to allow you to put a Transmitter out in a Zone with a Source.
As Postmoderndesign says HD over LAN is likely a more realistic option - like anything HDMI look for the Features you require and the systems with the best/least video processing.
Joe
post #286 of 291 Old 11-15-2016, 11:02 AM
carealtor's Avatar
A link would be much appreciated.
post #287 of 291 Old 11-15-2016, 10:08 PM
Quoted: 406 Post(s)
Liked: 225
You are looking at the cardframe type solutions from the likes of Crestron and Extron.
Joe
post #288 of 291 Old 11-26-2016, 03:43 PM
hellerbrewing's Avatar
Originally Posted by JaremyP View Post
Anyone know of an HDMI CATx extender capable of doing UHD/60Hz at 4:4:4 chroma with full 18+ Gbps bandwidth?
Most everyone I find tops out at 10+ Gbps, which means UHD?6Hz at 4:2:0.
I'm looking for one that supports full ARC as well. ARC seems to be a missing feature of most extenders.
Valens Responds: What’s the Road Map for 4K @60 MHz HDBaseT with 4:4:4?
What is the status of 4:4:4 at 60? Is the new standard that Valens was referring to in the above article HDBaseT 2.0? ...or have 2.0 devices been out for a while? It seems that 2.0 have been discussed on this thread for a few years now.
As an aside, i'm sure some updated information in the first post would be very helpful to those coming here looking for information.
hellerbrewing is offline
post #289 of 291 Old 11-26-2016, 03:53 PM
Has anyone used these?
AV Access HDMI Extender ( HDBaseT ),Uncompressed Signal 4K60Hz over Cat5e /6a, 70m(230ft)1080P, 40m(130ft) 4K, PoE, Bi-directional IR+RS232,HDR,HDCP2.2
Does the Valens "Lite" chip have any bandwidth limitations compared to the original version? Even if my distance is less than 70M, would it be advisable to spend the extra money and get the original?
AV Access HDMI/HDBaseT Extender,Uncompressed Signal 4K60Hz over Cat5e /6a, 100m(330ft)1080P, 70m(230ft) 4K, Supports Ethernet + PoE + RS232 + IR control + HDCP 2.2, Mounting Ear
post #290 of 291 Old 11-26-2016, 04:59 PM
So I found this device that claims to be HDBaseT 2.0 compliant:
GTB-UHD-HBT2
This is new, so I am assuming that this is the standard that was being referred to in the Valens article, but it appears that the only gain to be had from 2.0 is the increase in distance? They don't mention anything about throughput and they only claim to be able to get 4:4:4 at 30Hz.
Edit - Apparently 2.0 has been out since 2013, so maybe 3.0 is on the horizon?
What are the differences between HDBaseT Spec 1.0 and Spec 2.0?
The first HDBaseT standard specification was released in 2010. In mid-2013, the HDBaseT Alliance released Spec 2.0, which brought many new features to the original standard. Primarily, with Spec 2.0, HDBaseT is now a multipoint-to-multipoint technology, enabling networking of the whole home and/or business. Spec 2.0 brings a plug-and-play solution for full connectivity.
From an architecture standpoint, Spec 1.0 addressed the physical and data link layers only of the generic communications OSI 7-layer model. HDBaseT 2.0 goes one step further and work on all the layers of the model.
In terms of features, Spec 2.0 brings:
Native support for a series of interfaces, including USB 2.0, which translates into a smaller and simpler to implement switch;
Multistreaming & daisy-chaining
Enhanced performance for 4K delivery over longer distances
Introduction of HDBaseT over fiber
refernce
post #291 of 291 Old 11-29-2016, 03:36 AM
Quoted: 406 Post(s)
Liked: 225
Valens lists its 'available' products on its website - http://www.valens.com/products
Joe
Reply HDMI Q&A - The One Connector World
