The Unoffical source for everything HDBaseT - Page 9 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #241 of 248 Old 04-15-2015, 07:12 AM
JaremyP's Avatar
Quoted: 96 Post(s)
Liked: 37
Anyone know of an HDMI CATx extender capable of doing UHD/60Hz at 4:4:4 chroma with full 18+ Gbps bandwidth?
Most everyone I find tops out at 10+ Gbps, which means UHD?6Hz at 4:2:0.
I'm looking for one that supports full ARC as well. ARC seems to be a missing feature of most extenders.
JaremyP is online now
post #242 of 248 Old 05-19-2015, 09:24 AM
shepP's Avatar
Quoted: 26 Post(s)
Can anyone recommend the best "brand" to look at for HDbaseT? I know monoprice has some but I'm guessing better quality solutions exist from other manufacturers.
shepP is offline
post #243 of 248 Old 05-19-2015, 12:32 PM
AV_Integrated's Avatar
Quoted: 681 Post(s)
Liked: 539
HDBT does not support ARC on any of their products. So, if you see any extender which supports ARC, then it is not HDBT.
Likewise, Valens has HDBT chipsets which support HDMI 1.4 and UHD in 4:2:0, but not in 4:4:4 according to their website...
http://www.valens.com/products/vs2310
Hopefully in the next year or so, we will see products which can handle a bit more.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #244 of 248 Old 05-21-2015, 05:53 AM
shepP's Avatar
Quoted: 26 Post(s)
I'm looking for suggestions for equipment with two scenarios I'm working with.
1. At my house I need a matrix that will allow a minimum of 2 hdmi inputs - a satellite receiver and a media player (4 would be nice for future proofing). This will be located at a TV so I also need to send those 2 sources back to the TV. I then want to send the other two via cat6 to a 2nd TV location. In this scenario I also have a cat5e coming up from the basement theatre rack that would be awesome to tie in at some point for consoles in the rack however I also have an hdmi cable running the same path that I could also use.
2. Inlaws house. Cat6 to all TV locations (5 right now and maybe more later) which then terminate in an equipment closet in the basement. 2 Satellite receivers (1 for each floor of the house) to all locations eats up 2 inputs, maybe a bluray player or some other source down the line for a 3rd so a matrix will also be in order.
I know monoprice has great prices but I need 100% reliability without having to reset units every so often. I have also found in the past the hdmi switches I used degraded the picture quality (this might no longer be the case).
shepP is offline
post #245 of 248 Old 05-21-2015, 07:38 AM
Quoted: 58 Post(s)
Originally Posted by Joe Fernand View Post
Sno Crash – as Andy says either centralise your games console and control it remotely or have it ‘in zone’ and potentially send back its Optical Out over a single CAT cable using a lower cost Optical over CAT extender.
HD over LAN (no matter who’s badge is on the box) has to compress the video signal – it’s not a show killer for Commercial applications or smaller TV's but it looks ‘unnatural’ on a larger TV if you are used to viewing non-compressed HDMI.
We have recently introduced our own solution and its being going well in the commercial market - http://www.octavainc.com/HDMI_extender_LAN_HDDSX.html
Joe
Your post was a couple of years ago, but I assume the product is still on the market. I want to send a signal from my home theater to my kitchen. Both rooms are connected through a router and with Ethernet switches. Can I plug your transmitter into the switch in the theater room and the receiver into the switch in the kitchen and from there to a TV, thereby receiving the same signal in both room simultaneously? The distance is less than 100 feet. Will the sound sync, or will there be a delay?
Alanlee is offline
post #246 of 248 Old 05-22-2015, 08:06 AM
Joe Fernand's Avatar
Quoted: 89 Post(s)
Liked: 81
HD over LAN is still best suited to Commercial applications - though I have seen it used in Residential, esp. where you have a connection to a 'smaller' (sub 50") TV.
HDBT is still preferred for Residential - though it does require a 'direct' connection between the Transmitter and Receiver and not routed though your Network.
Joe
If I've helped 'Like' us on Facebook - www.facebook.com/Octavainc
Joe Fernand is offline
post #247 of 248 Old 05-22-2015, 10:31 AM
Quoted: 58 Post(s)
Joe
Thanks Joe - It is going to connect to a 48 inch TV and eventually to a back to back 38 inch TV. The line out would come from an AVR or a pre-pro. Now that I think about it, if I could put it on the network, I could send the signal all over the house with additional receivers to the bedroom and the patio because those TVS are also on the home network. Now what problems would I create for myself?
Alanlee is offline
post #248 of 248 Old Today, 04:41 AM
konieczn's Avatar
Quick question, I'm in the process of building a new home and throughout the process I've been buying products needed here and there.
I plan to have all of my set top boxes, receivers, etc. all inside centrally located closet.
I already have (2) Binary HDBaseT's but came across another one at a good price. Is it overkill to add another, making the total of HDBaseT's in the home at (3).
Just wanted to check with everyone to see if I should spend my money elsewhere, thank you for the support.
konieczn is online now
Reply HDMI Q&A - The One Connector World
