Splitting or Switching in this example - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 02-02-2012, 11:06 AM - Thread Starter
pburgh's Avatar
Quoted: 16 Post(s)
I have an HTPC running HDMI in to my Yamaha RX-V665 running HDMI in to my Samsung plasma TV. I've been experiencing some handshake issues, so I want to have the ability to run the HTPC directly to the TV (via HDMI) when I'm not using the AVR.
Seems that I need a 1-to-2 HDMI splitter. Is this correct?
The cable lengths are 6-10 ft. Will I have to worry about an amplified splitter?
Any suggestions on what unit to try out?
pburgh is offline
post #2 of 14 Old 02-02-2012, 11:14 AM
alk3997's Avatar
Liked: 92
You'll only get stereo with a standard splitter because the TV is stereo only. This will be true when the AVR is used with the splitter. Would that be a problem?
alk3997 is offline
post #3 of 14 Old 02-02-2012, 11:30 AM - Thread Starter
pburgh's Avatar
Quoted: 16 Post(s)
Oh... so splitting the HDMI prevents HD-audio (and 5.1, 7.1, etc) from going through? My home theater is only 2.1 right now (RTi A3 + LFM-1 Plus)... so not a big issue... but possibly issue for the future.
pburgh is offline
post #4 of 14 Old 02-02-2012, 11:42 AM
alk3997's Avatar
Liked: 92
It doesn't prevent it. What happens is the source device sees a stereo TV and tries to send a signal compatible with both the AVR and the TV. There are expensive splitter that will indicate 5.1 but then the TV won't have any audio because 5.1 won't be compatible with what it can handle. Remember HDMI can only send out one audio and one video signal at a time.
alk3997 is offline
post #5 of 14 Old 02-02-2012, 12:05 PM - Thread Starter
pburgh's Avatar
Quoted: 16 Post(s)
Ah, kind of like how they scale down to the lowest resolution for video. That's unfortunate.
So, let me ask this then... is there a product that will allow me to switch the output of the "box" with the HDMI running to it from HTPC? So, only one output is active. Is that what a standard HDMI switch does? Basically, I'll never use both outputs at the same time, I just want to use the HTPC+TV 99% of the time and have the option of using HTPC+AVR when a movie is on or something.
pburgh is offline
post #6 of 14 Old 02-02-2012, 05:58 PM - Thread Starter
pburgh's Avatar
Quoted: 16 Post(s)
Could I use something like
in reverse? Input from the HTPC with output to the AVR and TV?
pburgh is offline
post #7 of 14 Old 02-02-2012, 08:25 PM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
Nope... that's an "active" switch... it has to be used as designed because the electonics inside are setup up accordingly. IF you want a "reversible" switch, you have to find a "fully mechanical" switch (no things that say "amplified", "equalized", etc).. in most case, it will have push buttons and NO remote capability.
budwich is offline
post #8 of 14 Old 02-03-2012, 07:09 AM - Thread Starter
pburgh's Avatar
Quoted: 16 Post(s)
pburgh is offline
post #9 of 14 Old 02-03-2012, 01:15 PM
dar_p's Avatar
I thought HDMI switches are directional , which mean it has 2+ inputs and 1 out. Cannot connect other way as you mentioned above.
You would need bidirectional switch to use it in reverse ( usally its manual) like this. check this out.
Sewell Part #: SW-8876 Mfg Part #: HDMI121
dar_p is offline
post #10 of 14 Old 02-03-2012, 02:40 PM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
Like this?
I think if you do a search in and around this switch /topic, you will find out that mono sells "reversible" manual ones... they might require a small "mod" to remove a diode but overall that has also been "documented" both here and in the general web. I use a 3X1 cheapy offshore unit that works fine without any mod.
budwich is offline
post #11 of 14 Old 02-04-2012, 09:48 AM
Joe Fernand's Avatar
Quoted: 291 Post(s)
Liked: 168
What Handshaking Issues have you had problems with?
If its that your HTPC is going into hibernation mode when its not the 'active' Source a 1x2 won't solve the problem.
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is offline
post #12 of 14 Old 02-04-2012, 07:19 PM - Thread Starter
pburgh's Avatar
Quoted: 16 Post(s)
When running through the avr, certain HD channels drop audio and video, making it impossible to watch. Bypassing the avr solves the issue.
pburgh is offline
post #13 of 14 Old 02-05-2012, 07:54 AM
Quoted: 291 Post(s)
Liked: 168
Is the problem only with your Tuner card in the PC - is BD/DVD and streamed content OK?
Try limiting the PC to 2.1 audio!
Joe
post #14 of 14 Old 02-06-2012, 05:42 AM - Thread Starter
pburgh's Avatar
Quoted: 16 Post(s)
Joe... the problem occurs when I use my GT430 HDMI or the on-board (ATI) HDMI. I have not tried setting the sound to 2.1 though. The issue does not occur when watching streams, blu-rays, dvds, etc. So, if it was a 2.1 issue, I could just use 2.1 for normal TV watching, then flip over to 5.1/7.1 for movies? Great tip! I'll test it out today.
EDIT: Forgot one detail... when I do experience the audio/video drop out... if I minimize the media center window on the screen (to a size smaller than full screen), the issue goes away. To put it another way, the issue only happens on certain channels when media center is in full screen mode.
pburgh is offline
Reply HDMI Q&A - The One Connector World
