Connect 2 order new 35 ft hdmi cable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-04-2012, 10:32 PM - Thread Starter
wriley1's Avatar
I have a high speed 25 ft hdmi cable but am in need of about 32 ft. If I just add a 10 ft cable could that work for 1080p and 3d or do I order a good 35 ft cable. I am running it from my 3d tv to my marantz av receiver.
I appreciate any advice
wriley1 is offline
post #2 of 5 Old 02-05-2012, 10:45 AM
alk3997's Avatar
Liked: 93
Everything being equal, adding a 10 foot high speed cable should work. Make sure the gauge is fairly high. Of course, there are no guarantees so make sure you have a good return policy at the store. If it doesn't work, it will be obvious not subtle.
alk3997 is offline
post #3 of 5 Old 02-05-2012, 01:38 PM
Colm's Avatar
Liked: 94
Just be aware that a 25' high speed HDMI cable plus a 10' high speed HDMI cable does not equal a 35' high speed HDMI cable. All other things being equal, the longer the cable, the lower the bit rate it will support. But you ought to be able to do 1080p60 2D or 1080p24 3D at standard color depth at that length with good cables.
Colm is offline
post #4 of 5 Old 02-24-2012, 09:01 AM
charlievoviii's Avatar
i have a question for you experts. I have my 3D blu ray player hook to my receiver that have 1.4A, I need to run about 35-40feet of hdmi cable from my AV receiver to my Epson 5010 3d projector that's also have 1.4A. I want the best picture reserve without any lost, like deep color and not loosing any bits. So my question what's the best way of doing this ? do i get two hdmi cables and a hdmi extender/repeater box ? Any brand of cables you guys recommend without killing my bank account lol. thanks in advance.
charlievoviii is offline
post #5 of 5 Old 02-24-2012, 11:40 AM
alk3997's Avatar
Liked: 93
If it were me, I'd start by reading this thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1395991
And, why do you want deep color enabled?
alk3997 is offline
Reply HDMI Q&A - The One Connector World
