Laptop to LCD TV via HDMI not working - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-07-2012, 09:29 AM - Thread Starter
looroll's Avatar
Hello all,
I'm new to the forum and hope someone can help, I have a Samsung laptop (details below) with a HDMI port and I recently purchased a 32" BUSH LCD TV and a Belkin HDMI cable. When I connect the Laptop to the TV via the HDMI cable nothing happens :/ . It works fine when I connect using a VGA cable but neither the laptop nor the TV show any sign of recognising the other when connected by HDMI cable.
Below I have listed the full spec of the laptop and TV, if anyone requires any more information I'd be happy to provide it.
Kind Regards
Liam
Laptop details:
Model No: Samsung NP-R510-FAA2UK
OS: Vista Home premium SP 2
Processor: Intel Core2 Duo T5750 @ 2.00GHz
Ram: 4GB
Graphics Card:
Chip Type: Mobile Intel(R) 4 series Express Chipset Family
Adapter String: Mobile Intel(R) GMA 4500 MHD
Driver Date: 11/02/2011
Driver Version: 8.15.10.2302
TV Details:
Type: Bush 32" LCD
Model #:BLCD32HB
looroll is offline
post #2 of 10 Old 02-07-2012, 10:43 AM
alk3997's Avatar
Liked: 92
Originally Posted by looroll View Post
Hello all,
Kind Regards
Liam
Laptop details:
Ram: 4GB
Graphics Card:
TV Details:
Type: Bush 32" LCD
Model #:BLCD32HB
Welcome to the AVS Forum! The first thing to look at is whether you have the HDMI port enabled on the laptop. Check your laptop video settings and make sure that HDMI is enabled.
If that doesn't work, let us know.
alk3997 is offline
post #3 of 10 Old 02-07-2012, 01:37 PM - Thread Starter
looroll's Avatar
Hi Andy,
Thanks for getting back to me, I've had a look around at all the usual settings on the control panel in "personalise" but for the life of me I cant see any settings for the HDMI port (It def has one though lol). I have even searched for HDMI in search and downloaded the latest drivers for the graphics card from Samsung support.
Any Ideas?
Liam
looroll is offline
post #4 of 10 Old 02-07-2012, 02:12 PM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 852
Does the HDMI port on the tv need to be "labeled" PC? I know on some tv's you can change the name of the HDMI port which will allow easier use. When we connect our MBP via mini-HDMI to HDMI on the LG I have that particular port label changed to PC and it works perfectly, like a very large external monitor.
Otto Pylot is online now
post #5 of 10 Old 02-07-2012, 02:40 PM - Thread Starter
looroll's Avatar
Hi Otto, unfortunately the TV is on the budget side of things so no fancy renaming option lol, I'm going to take the HDMI cable and get exchanged to rule out that it's not faulty. After that It's time to rule out the never before used HDMI port on the laptop. Cheers
Liam
looroll is offline
post #6 of 10 Old 02-08-2012, 02:52 PM
alk3997's Avatar
Liked: 92
Liam
You can rule out the cable quicker by connecting that cable to a different source component that has an HDMI output.
alk3997 is offline
post #7 of 10 Old 02-08-2012, 03:21 PM
Joe Fernand's Avatar
Quoted: 281 Post(s)
Liked: 164
You normally have to toggle the external video port on the Laptop on/off using Fn + F7 or some other keyboard combination.
Look for a 'monitor' Icon on one of your 'F' buttons.
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is online now
post #8 of 10 Old 02-12-2012, 03:19 PM - Thread Starter
looroll's Avatar
Hi Everyone sorry for the delay,
** The laptop is the only thing I own that has a HDMI port :/
Originally Posted by joeten View Post
Keep us posted
So, I got the HDMI cable replaced today for another new one. Still the same problem though :/ Its also a brand new TV is it likely to be a fault with the TV or the HDMI port on the Laptop?
Liam
looroll is offline
post #9 of 10 Old 02-12-2012, 10:37 PM
alk3997's Avatar
Liked: 92
Liam
I would not have expected a new cable to fix the problem. Joe is correct in that unless you enable the HDMI port with an Fn key combo, the port will be dead. Basically most laptops toggle from laptop display only to external display only to both displays simultaneous and then back to the beginning.
alk3997 is offline
post #10 of 10 Old 02-27-2013, 05:52 AM
Tinman1952's Avatar
Hi , if you haven't resolved the " laptop to TV via HDMI " this might help . I have a Samsung RV511 Notebook and to connect it to the TV , I type HDMI into the "start search box" then select "connect to a projector" . This will then give you four option windows ........
COMPUTER ....................DUPLICATE..............EXTEND.............PROJECTOR ONLY .
Hopefully your laptop will be similar.
Just click whichever you want , that should put your laptop picture through to the TV via HDMI,
There's probably other ways via the control panel as well .
Regards Tinman
Tinman1952 is offline
Reply HDMI Q&A - The One Connector World
