30ft hdmi for my projector, will monoprice do the trick? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-24-2012, 06:03 PM - Thread Starter
deathinc's Avatar
I need a 30ft hdmi for my projector. I was looking at monoprice but all they have is 30ft+ standard speed cables. The high speed are max at 25ft. I dont want to spend more than $40 on an hdmi cable (greedy me ). I chatted with their tech support than they told me that the standard speed cable will do 1080p with no issues. Is this true or should I look somewhere else?
Av123 Onix Rockets RS1000 , AV123 RSC200 BIGFOOT, B&W WM6 White, Denon AVR-4311CI 9.2
DIY Stereo Integrity SI 18" Subwoofer X2, HTPC Running XBMC 14TB , Roku HD Player
Sony VPL-VW70 Pojector, Xbox 360 250GB, Yamaha RX-V573
deathinc is offline
post #2 of 7 Old 02-24-2012, 07:18 PM
Archaea's Avatar
Quoted: 2845 Post(s)
Liked: 2427
It should fine. We run one at work with no problem. Lately it seems lik partsexpress.com is cheaper on HDMI cables than momporice.
Archaea is online now
post #3 of 7 Old 02-25-2012, 07:32 AM
alk3997's Avatar
Liked: 92
And, if you haven't already, you should read through this thread, particularly the points over the last two days or so.
http://www.avsforum.com/avs-vb/showthread.php?t=1395991
alk3997 is offline
post #4 of 7 Old 04-20-2012, 03:44 PM
ShowMeCablesDrew's Avatar
Standard speed HDMI cables are rated for 1080i/720p. In shorter runs they can support 1080p, but I suggest getting a high speed cable which will be able to handle 1080p no problem
ShowMeCablesDrew is offline
post #5 of 7 Old 04-20-2012, 07:38 PM
alk3997's Avatar
Liked: 92
I'm curious, which certified high speed 30' cable have you found that the rest of us haven't? Last we heard the max distance on a high speed cable just a hair over 25'.
alk3997 is offline
post #6 of 7 Old 04-27-2012, 09:31 AM
I have used 60 foot ( 20 meter) high speed cables. They do 3d 1080p with out any issues. Now if they are certified, that is another question.
post #7 of 7 Old 04-27-2012, 11:12 AM
alk3997's Avatar
Liked: 92
If they aren't certified, they don't exist. The only difference between a standard speed cable and a high speed cable is the certification that shows the high speed cable is capable of the maximum HDMI bandwidth, which would be well beyond 1080p/24 3D. Of course, there could be manufacturing and material differences that allow the cable to be certified for high speed versus a standard-speed cable.
What you have is a standard speed HDMI cable that can do 1080p/24 3D. And yes, it is even possible to get a standard speed 50' cable to 1080p/60 with deep color (or even greater lengths) but that doesn't make that a high speed cable and it may not (or may, we don't know) work for 4K. So just because a cable can handle 1080p/24 3D (or even 1080p/60) doesn't make it a true HDMI high speed cable.
Some knock-off manufacturers are claiming to sell high speed cables but all they've done is shown that 1080p/60 works with the cable. That isn't a high speed cable and is in violation of the HDMI adopters agreement. Those are standard speed cables.
alk3997 is offline
Reply HDMI Q&A - The One Connector World
