What should I look for in an HDMI cable ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 45 Old 02-28-2012, 08:05 AM - Thread Starter
RicFlair's Avatar
Quoted: 488 Post(s)
Liked: 70
I have a 3D tv - do I need a certain kind?
I see these gold plated ones ? Monster etc ? Is there a best brand ?
RicFlair is offline
post #2 of 45 Old 02-28-2012, 08:15 AM
Ratman's Avatar
Quoted: 1276 Post(s)
Liked: 1024
Ratman is offline
post #3 of 45 Old 02-28-2012, 08:42 AM
thewayout2217's Avatar
Brand does not matter. There is no visible difference between a $50 monster HDMI or one of those $2 ones. Get the cheapest one there is. Dont pay more than like $8 in store for one if you dont want to wait to have it shipped.
thewayout2217 is offline
post #4 of 45 Old 02-28-2012, 08:45 AM
saeyedoc's Avatar
Quoted: 82 Post(s)
Liked: 69
Make sure you don't buy anything shorter than 4'.
saeyedoc is offline
post #5 of 45 Old 02-28-2012, 09:08 AM
Ratman's Avatar
Liked: 1024
There's a head scratcher.
Why???
Ratman is offline
post #6 of 45 Old 02-28-2012, 09:09 AM
saeyedoc's Avatar
Quoted: 82 Post(s)
Liked: 69
I was told that you can have problems with the HDMI handshake with shorter ones. I saw some posts on this forum and verified it with tech support at Monoprice.
saeyedoc is offline
post #7 of 45 Old 02-28-2012, 09:13 AM
8mile13's Avatar
Quoted: 1479 Post(s)
Liked: 825
HDMI version 1.4/1.4a supports Stereoscopic 3D and 4K x 2K resolution.
hdmi - Wikipedia
http://en.wikipedia.org/wiki/HDMI
hdmi.org
http://www.hdmi.org/manufacturer/hdm...i_1_4_faq.aspx
8mile13 is offline
post #8 of 45 Old 02-28-2012, 09:14 AM
Ratman's Avatar
Liked: 1024
That's odd. If that were a problem, why sell HDMI cable shorter than 4'.
Ratman is offline
post #9 of 45 Old 02-28-2012, 09:17 AM
Ratman's Avatar
Liked: 1024
HDMI "versions" 1.4 refer to the source/destination hardware... not the cable itself. As recommended previously, all that is required is a "high speed" HDMI cable.
http://www.hdmi.org/manufacturer/hdm...ght_cable.aspx
Ratman is offline
post #10 of 45 Old 02-28-2012, 09:28 AM - Thread Starter
RicFlair's Avatar
Quoted: 488 Post(s)
Liked: 70
Very cool - Thanx
RicFlair is offline
post #11 of 45 Old 02-28-2012, 09:54 AM
8mile13's Avatar
Liked: 825
1.3 versions are also ''high speed'' but - 1.3 versions do not support Stereoscopic 3D and 4K x 2K resolution according to the Wikipedialink. So you could buy some (former 1.3) ''high speed'' cable and find out at the house that 3D doesn't work with this cable.
8mile13 is offline
post #12 of 45 Old 02-28-2012, 10:02 AM - Thread Starter
RicFlair's Avatar
Quoted: 488 Post(s)
Liked: 70
Should I trust mono price ?
RicFlair is offline
post #13 of 45 Old 02-28-2012, 11:08 AM
ozar's Avatar
Liked: 152
Absolutely... that's where all my cables and wiring come from and I've never had any problems with their stuff, but always great quality and prices. Shipping is fast and well packaged, too.
oz
ozar is offline
post #14 of 45 Old 02-28-2012, 11:09 AM
BoilerJim's Avatar
Quoted: 55 Post(s)
Liked: 118
Definitely yes. Great cables at a low price (also an AVS Forum sponsor).
I also like "Cables on Demand" (cablesondemand.com). They sell Amphenol cables, a well-respected brand as well.
BoilerJim is offline
post #15 of 45 Old 02-28-2012, 11:35 AM
ozar's Avatar
Liked: 152
...oh, and another good thing about monoprice is their knowledge database regarding their products and the instructional videos that they offer to help purchasers.
oz
ozar is offline
post #16 of 45 Old 02-28-2012, 12:11 PM
Ratman's Avatar
Liked: 1024
Re-read all of the FAQ's and info from Monoprice and the links you provided.
There is "standard speed" and "high speed". Also... HDMI cables cannot be packaged/advertised as 1.3 or 1.4 etc. This was done to avoid "confusion". Apparently, that didn't work well.
The only caveat is if you require an "ethernet" HDMI cable. Then, you need to purchase one designated as "ethernet". The only problem with that is... are there any TV's/receivers/devices that support ethernet over HDMI?
EDIT:
From the wiki link
As of the HDMI 1.4 specification, these are the following cable types defined for HDMI in general:[71][72]
Standard HDMI Cable – up to 1080i and 720p
Standard HDMI Cable with Ethernet
Automotive HDMI Cable
High Speed HDMI Cable – 1080p, 4K, 3D and deep color
High Speed HDMI Cable with Ethernet
Ratman is offline
post #17 of 45 Old 02-28-2012, 12:35 PM
greenjp's Avatar
Quoted: 32 Post(s)
Liked: 37
No problems per se with shorter cables. I think the advice is intended to avoid the problem of a too-short cable. 4' is less than you think when you're routing the cable from the box, out the back of a cabinet/shelving/etc up and around to the TV. A 6' cable may be a safer bet and minimally more expensive.
jeff
greenjp is offline
post #18 of 45 Old 02-28-2012, 12:52 PM
saeyedoc's Avatar
Quoted: 82 Post(s)
Liked: 69
jeff
No, this was a specific recommendation from Monoprice regarding communication issues. Damn, they stuck me for an extra $1 for the longer ones lol. I wish they had told me 6' minimum, the 4's are too short anyway.
saeyedoc is offline
post #19 of 45 Old 02-28-2012, 12:57 PM
Ratman's Avatar
Liked: 1024
jeff
That's fine and good advice. We need to differentiate between a "technical" issue or a "common sense" issue.
Ratman is offline
post #20 of 45 Old 02-28-2012, 01:49 PM - Thread Starter
RicFlair's Avatar
Quoted: 488 Post(s)
Liked: 70
Am I reading correct that different hdmi will do 1080p?
So a regular wire doesn't do full 1080p?
RicFlair is offline
post #21 of 45 Old 02-28-2012, 01:52 PM
NickTheGreat's Avatar
Quoted: 381 Post(s)
Liked: 255
Why???
I had trouble with 18" HDMI cables with my switch and 3D and Blu Ray content. The longer cables seem to work just fine.
NickTheGreat is offline
post #22 of 45 Old 02-28-2012, 01:55 PM
Quoted: 381 Post(s)
Liked: 255
jeff
I had a HDMI switch and a couple 18" cables going to my receiver. I RMA'd the switch, before coming to the realization it was the short cables. I only had trouble with 3D or Blu-Ray content.
And FWIW Monoprice put the 4' minimum warning up on the switch page not too long thereafter.
post #23 of 45 Old 02-28-2012, 03:31 PM
Ratman's Avatar
Liked: 1024
Using a "switch" is not the same as using a 4' or < HDMI cable. Consider that a "switch" or perhaps other components may act as a repeater or signal regenerator, boosting the signal(s). Not the same IMHO...
To the OP:
Read the info in the links and recommendations. "High Speed" HDMI cables will carry 1080P and 3D info and everything you desire.
Ratman is offline
post #24 of 45 Old 02-28-2012, 06:01 PM
8mile13's Avatar
Liked: 825
EDIT:
From the wiki link
seems that only (former) version 1.4 and above is ''high speed''.
8mile13 is offline
post #25 of 45 Old 02-28-2012, 06:28 PM
plasmalvr's Avatar
One website for all your cable needs: www.monoprice.com. Expensive cables don't improve picture or audio quality- anything that the human eye or ear can perceive.
Monster Cables should have a big sign in the lobby of their headquarters that says, "A Sucker Born Every Day"- stealing a quote from P.T. Barnum
Pioneer Elite Pro-1120 HD Plasma with Cable Card
Chief Wall Mount Bracket
Paradigm Mini Monitor L/R Front, CC-170 Center, AMS-100 L/R Rear Speakers, and PS-1000 Subwoofer.
Denon AVR-2800 Receiver
plasmalvr is offline
post #26 of 45 Old 02-28-2012, 07:04 PM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 852
I agree about the "M" brand, and I'm not talking about Monoprice. For most of us, a High Speed HDMI cable that comes with a certificate (which should specify length as well) is all we need. Ethernet is superfluous as is ARC (for a lot of people). If you get cables with those that's fine. It won't hurt anything. The HDMI version numbers are for hardware, not the cable. A certified High Speed cable will work fine with hardware version 1.3a, etc. Another good brand of cable is MediaBridge. If you're installing your cable run in a wall, there are a couple of other things to consider but that has more to do with shielding than type.
Otto Pylot is online now
post #27 of 45 Old 02-28-2012, 08:43 PM
Yes that is correct. Components only handle 1080i/720p. Hdmi is the only cable that can handle 1080p
post #28 of 45 Old 02-29-2012, 05:40 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
With your life!
joed32 is offline
post #29 of 45 Old 02-29-2012, 12:52 PM
Jben04's Avatar
Quoted: 51 Post(s)
Ive just recently purchased a HDMI cable from mono price,excellent price as well as damn fast shipping....
my only thing is that the one i purchased is quite stiff,,("6ft 24AWG CL2 Flat High Speed HDMI Cable With Ethernet ")
,as i have a lg LW5600, the HDMI port is on the side and my BD player is situated under the TV ,,seems the cable is pulling down on the weight of itself. just hope it doesnt cause a problem,...with that in mind im ordering more from monoprice next week
LG 47LW5600 (3D) - Energy take classic 5.0 - SVS PB-1000 - Panasonic BDT220 (3D) - Sony BD S350 - Insignia NS BRDVD4 (Region Free) -
Denon AVR X2100W - Harmony One Remote - Harmony Ultimate One.
Jben04 is offline
post #30 of 45 Old 02-29-2012, 03:00 PM
Otto Pylot's Avatar
Liked: 852
Usually those flat CL2 cables are for wall installations where there will be minimal bending. I had cables like that a long time ago but replaced them for the "round" type that has a little more flexibility and don't stress the connectors. Ethernet is ok but you don't really need it so I'd suggest getting certified High Speed cables without enet unless there isn't a price difference.
Reply HDMI Q&A - The One Connector World
