4' HDMI question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 03-08-2012, 06:20 PM - Thread Starter
Lyons07's Avatar
Quoted: 108 Post(s)
Liked: 26
Hi,
I have a 4' HDMI cable. It is Hi Speed 30 awg. Will this be OK to use for all my equipment...Bluray player dual hdmi's, Comcast with Motorola Digital Set-Top Box? If not, please advise me of of what awg I should use, if these aren't the right ones?
Thanks, Jerry
UN60HU8550 HS01 SEK-3500 Denon X4300h Samsung UBD-K8500 4K Ultra HD
Lyons07 is offline
post #2 of 14 Old 03-08-2012, 07:28 PM
Colm's Avatar
Liked: 94
Since you already have the cable, try it and see. If you are not getting sparkles or worse, the picture is as good as it gets.
Colm is offline
post #3 of 14 Old 03-08-2012, 07:34 PM - Thread Starter
Lyons07's Avatar
Quoted: 108 Post(s)
Liked: 26
Hi,
Thanks for the reply! I've tried it on my Comcast top box and that seems fine. I should have said, I have a 3D Bluray player? I can return them if need be. What do you think about the Bluray player, with dual HDMI"s? Go with a better cable> Monoprice net jacket 24 awg, doesn't have much bend to it. Thanks in advance.
Jerry
Lyons07 is offline
post #4 of 14 Old 03-08-2012, 07:51 PM
Colm's Avatar
Liked: 94
Well, if what you have is truly a certified high speed HDMI cable, you don't need anything else. A certified high speed HDMI cable will handle any HDMI signal. You certainly don't need 24 AWG for 4'.
Colm is offline
post #5 of 14 Old 03-08-2012, 08:02 PM - Thread Starter
Lyons07's Avatar
Quoted: 108 Post(s)
Liked: 26
Hi,
This is what I got....Monster THX.....Monster Cable 500 for HDMI....Hi Speed 10.2 Gbps
Would this be OK for the Bluray player, for video and audio?
Thanks again, Jerry
Lyons07 is offline
post #6 of 14 Old 03-08-2012, 08:08 PM
Otto Pylot's Avatar
Quoted: 1363 Post(s)
Liked: 854
Originally Posted by Lyons07 View Post
Hi,
Thanks again, Jerry
As long as it's certified (and you can get/view the certificate) it will be fine. However, you probably paid a lot more for the Monster cable than you needed to. I use a certified High Speed 4' cable for my BD player to AVR and it works just fine (and I paid $8 for the cable).
Otto Pylot is offline
post #7 of 14 Old 03-08-2012, 08:19 PM - Thread Starter
Lyons07's Avatar
Quoted: 108 Post(s)
Liked: 26
Hi,
I only paid 10.00 for it. I'm guessing not too bad. Where would I find the certificate at...on the box someplace or a tag, on the hdmi?
Thanks, Jerry
Lyons07 is offline
post #8 of 14 Old 03-08-2012, 08:31 PM - Thread Starter
Lyons07's Avatar
Quoted: 108 Post(s)
Liked: 26
The box states all over it about Hi Speed. This is the original OEM box.
This is on the box...The official hi speed data rate as specified by HDMI licensing, LLC is 4.95 Gbps unequalized, 10.2 Gbps equalized. Is this what I'm looking for? It also states on the hdmi, hi speed.
Thanks, Jerry
Lyons07 is offline
post #9 of 14 Old 03-08-2012, 09:14 PM
alk3997's Avatar
Liked: 92
Thanks, Jerry
Colm gave you the best advice. Try it. At $10, you don't have much to lose. If you see sparkles or lines or no picture at all, it's likely the cable. If not you're good to go. Give it about 10 minutes with a 1080p/60 source (or 1080p/24 if that is all you have). Any cable problem will be very obvious (not subtle).
High Speed HDMI is as good as it gets and 4' is short. So, you shouldn't have a problem based on the specs.
alk3997 is offline
post #10 of 14 Old 03-08-2012, 09:18 PM - Thread Starter
Lyons07's Avatar
Quoted: 108 Post(s)
Liked: 26
Thanks, I'll try that!!
Lyons07 is offline
post #11 of 14 Old 03-08-2012, 10:00 PM
Otto Pylot's Avatar
Liked: 854
Hi,
Thanks, Jerry
$10 for a Monster cable is not bad. The packaging should say certified on it and the certificate is either in the packaging or you should be able to view or download it on the Monster site. I'm not sure how that works. I bought mine from MediaBridge and the certificate that was specific for the cable came in the package.
post #12 of 14 Old 03-08-2012, 11:04 PM
Colm's Avatar
Liked: 94
Seems Monster has targeted a wider market. These cables are widely available at places like Walmart ($7.88). It is a bare bones 30 AWG cable. I checked Simplay Labs listing of certified cables and this one doesn't show up. Maybe it wasn't certified. Maybe it just hasn't shown up yet. In any case, a 4', it should work just fine.
Colm is offline
post #13 of 14 Old 03-09-2012, 06:27 AM - Thread Starter
Lyons07's Avatar
Quoted: 108 Post(s)
Liked: 26
Thanks all, I'll give Monster a call and see what they say!
Lyons07 is offline
post #14 of 14 Old 03-09-2012, 09:47 AM
alk3997's Avatar
Liked: 92
Must mean their "higher priced" market is drying-up. Time to cut down on margin and increase number of sales.
As BB (and other electronics retailers) move towards mobile devices, less high-priced items will be available in retail stores.
Of course, in this case it doesn't leave much of a hole - or any hole since the lesser (much lesser) priced cables do just as good (or better in some cases).
alk3997 is offline
Reply HDMI Q&A - The One Connector World
