1 Input/2 Output HDMI Switch?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 04-28-2012, 08:16 AM - Thread Starter
rgathright's Avatar
Quoted: 216 Post(s)
Liked: 26
I need a 1 input and 2 output HDMI switch for my Home Theater room that will work with Directv. I want to watch my movies on my projector and regular programming on my 40". I don't want to go the AVR switching route.
Sony XBR-75X850C - Living Room
Samsung UN60J6300AFXZA - Bedroom
rgathright is offline
post #2 of 17 Old 04-28-2012, 08:47 AM
dharel's Avatar
Liked: 33
dharel is offline
post #3 of 17 Old 04-28-2012, 09:11 AM
alk3997's Avatar
Liked: 91
Just to make sure you understand, in this configuration you will likely only get stereo audio output. That said, Monoprice is the cheapest for a reliable distribution amp.
alk3997 is offline
post #4 of 17 Old 05-14-2012, 10:21 AM
pbaxter's Avatar
@alk3997 -
Just to clarify: Even if the HDMI input to the Monoprice product carries 5.1 audio, the HDMI outputs will carry only 2-channel stereo audio?
A newbie thanks you in advance. . .
pbaxter is offline
post #5 of 17 Old 05-15-2012, 05:58 AM
alk3997's Avatar
Liked: 91
Originally Posted by pbaxter View Post
@alk3997 -
Sort of. The source device is told by the destination (the sink - which is the AVR and TV in this case) what capabilities the sinks have. The source then adjusts its output the match the capabilities of both sinks. So, the source will only *send* 2-channel audio out if a single 2-channel sink (a TV, for instance) is included as one of the outputs.
So it isn't the outputs that change to 2-channel, but instead it is the input that becomes 2-channel. This is the lowest common denominator principal and is part of the EDID communications you'll hear about. Remember HDMI only includes a single audio stream at any time.
alk3997 is offline
post #6 of 17 Old 05-15-2012, 01:05 PM
pbaxter's Avatar
Thanks, Andy. That helps.
I'm trying to split the hdmi output from my TIVO to go both to an hdmi input on the TV and to an hdmi input on my receiver.
If the tv can process 5.1 all will be well.
If it can't, then the receiver will be getting 2-channel stereo. In that case I think I can run an optical audio cable from the TIVO to the receiver and assign it to the input to which the TIVO is attached.
Does this sound ok?
pbaxter is offline
post #7 of 17 Old 05-15-2012, 01:21 PM
alk3997's Avatar
Liked: 91
Does this sound ok?
Yes, that's the correct way of handling this.
alk3997 is offline
post #8 of 17 Old 05-15-2012, 02:02 PM
pbaxter's Avatar
The Monoprice line has been mentioned elsewhere on this forum - I'm thinking of their model "8204 1X2 Mini HDMI® Splitter w/ 3D support".
pbaxter is offline
post #9 of 17 Old 05-15-2012, 03:30 PM
alk3997's Avatar
Liked: 91
That should be fine for your application with your plan to use a S/PDIF cable as well for digital audio.
alk3997 is offline
post #10 of 17 Old 05-15-2012, 08:58 PM
sunkeycoco's Avatar
www(dot)lenkeng(dot)biz/Html/Product/1x2-hdmi-splitter.html
another choice for you ,you can also find perfect product from this manufacturer
sunkeycoco is offline
post #11 of 17 Old 05-15-2012, 10:34 PM
zeroputt's Avatar
I found some splitters here as well
-Carter.
zeroputt is offline
post #12 of 17 Old 06-30-2012, 02:16 PM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
I've tried a lot of different switches and splitters and finally found one that works like a charm. I'ts a bi-directional HDMI switch from Sewell with HDCP pass through and it's $24.99 shipping was $2 and change. I'm going to order a couple more.
http://sewelldirect.com/2x1-or-1x2-HDMI-Bi-Directional-Switch-with-HDCP-Passthrough.asp
joed32 is offline
post #13 of 17 Old 07-12-2012, 10:12 AM
bmcleod's Avatar
So this may be a question for individual TV vendors but I'll give it a shot. If an HDTV out of the box just does stereo then an HDMI splitter would negotiate down to two channel. What if later you used the TV's TOSLink out to drive a 5.1 soundbar system, is the HDMI circuit/handshake now aware that the TV is 5.1 capable? Will future handshakes with this device be at 5.1? (assuming the other splitter device is also 5.1).
bmcleod is offline
post #14 of 17 Old 07-12-2012, 10:29 AM
alk3997's Avatar
Liked: 91
If I understand soundbars correctly, if the soundbar has an HDMI input, the HDMI signal is usually sent to the soundbar first and then to the TV (using the soundbar's HDMI output). It allows the soundbar to alter the EDID and pass along the TV video information.
For non-HDMI soundbars, it will depend upon whether the TV sends 5.1-channel output with the Toslink. Many were limited to sending 2-channel for HDMI inputs. If you used a direct cable or antenna TV station then 5.1-channel could be sent out the Toslink connector. Again, it's a situation where each specific TV model may be different.
alk3997 is offline
post #15 of 17 Old 07-22-2012, 06:46 PM
taxman48's Avatar
Quoted: 300 Post(s)
Liked: 296
Another recommendation for the Monoprice #8204.. 1 in 2 out splitter. Works flawlessly with my small 21" monitor and my big 52" Sony Bravia.. No problems yet, just plug in power and plug in your cables..
taxman48 is offline
post #16 of 17 Old 07-12-2015, 12:37 PM
Liked: 0
I have a setup where my Directv box is connected to my Denon receiver with HDMI and to my TV with component cables (just video). I like to watch sporting events without sound using sound from either tuner or blu ray player through receiver. This has worked fine until recently and it appears that the culprit is HDCP error from DirectV box. I can switch to SD channels to watch but not HD. From what I have read here a 1x2 HDMI splitter will not work as my sound will be reduced to stereo. If I have TV speakers turned off will I be able to get 7.1 sound through my stereo?
rocky722 is offline
post #17 of 17 Old 07-12-2015, 12:57 PM
Liked: 0
I think the question I asked is a stupid one as I would be getting sound from stereo from a totally different source (i.e. Blu Ray - Pandora or Rhapsody or connected to my network) connected with a different HDMI. I think a HDMI 1x2 splitter should solve my problem??
rocky722 is offline
Reply HDMI Q&A - The One Connector World
