HDMI to projector with CAT5 Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-03-2012, 04:28 PM - Thread Starter
DrewSO's Avatar
Hey AVS! First post BTW.
I have a projector that has 3 CAT5's run to it. So I was thinking to purchase one of these "Tripp Lite P167-000 HDMI over Cat5 Active Extender Wall Plate Kit" on amazon. Sorry I can't post a link yet.
Its for a blu-ray player that only has an HDMI output. Anyone have any experience with this plate on here? Its pretty much my only option without cutting some drywall.
DrewSO is offline
post #2 of 7 Old 05-03-2012, 05:30 PM
alk3997's Avatar
Liked: 92
Cat 5 (instead of 5e or 6) makes this tougher. I've seen some dual cable cat 5 solutions. Just make sure the converter is to the HDMI revision number or capability you use (if you use 3D, make sure the converter can handle 3D) and that it doesn't compress the video or audio signal.
alk3997 is offline
post #3 of 7 Old 05-03-2012, 06:14 PM - Thread Starter
DrewSO's Avatar
Sorry about that. It is Cat5e.
DrewSO is offline
post #4 of 7 Old 05-03-2012, 06:28 PM
alk3997's Avatar
Liked: 92
Should be a much easier solution with 5e. I probably recommend looking at the Octava web site too much (I don't have any tie-in), but it's a good place to start while looking. You can then look elsewhere for cheaper, but at least you'll know what is available.
My very quick look at the Tripp Lite concerns me because the ad says "1080p (24Hz)". If it can't handle 1080p/60, then your Blu-Ray menus and computer output may not be visible. The other concern is that it gets its power from the HDMI cable. That has been a problem for many users since many devices don't supply enough power to then also power a converter. As I said, that was a very quick look.
alk3997 is offline
post #5 of 7 Old 05-03-2012, 09:47 PM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 852
Sorry to hijack this thread but what's the difference between CAT-5 and CAT-6? I bought some CAT-6 for a video security system (not paying attention to the package) and it seems to work ok with "standard" ethernet device connections.......
Otto Pylot is offline
post #6 of 7 Old 05-04-2012, 02:22 AM
Colm's Avatar
Liked: 94
The difference is primarily in the precision with which it is made. That results in tighter control of impedance, which minimizes unwanted reflections, allowing better performance. There are also changes that help reduce crosstalk. In your case, all it does is give you a little more headroom.
Colm is offline
post #7 of 7 Old 05-04-2012, 07:54 PM
Otto Pylot's Avatar
Liked: 852
Reply HDMI Q&A - The One Connector World
Cat5 Rack 1u
