HDMI issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-04-2012, 05:22 PM - Thread Starter
Gmojo's Avatar
I am using a computer with a ceton 4 tuner card with AMD Radeon HD 6500 Series video card. I am not getting sound using the HDMI port. I get sound through the HDMI port from my laptop.
How can I get the sound to go through the HDMI port? Thanks.
Gmojo is offline
post #2 of 5 Old 06-04-2012, 05:40 PM
alk3997's Avatar
Liked: 92
If it is Windows 7, did you select the appropriate HDMI port in the Device Manager -> Sound section? Also some cards require that the HDMI port audio be enabled with the card's drivers.
Gmojo likes this.
alk3997 is offline
post #3 of 5 Old 06-06-2012, 11:21 AM - Thread Starter
Gmojo's Avatar
Yes it's WIndows 7
There are two options in the sound section
AMD High Definition Audio Device
VIA High Definition Audio
When I go to properties the only options are to: Driver Details/update Driver/Roll Back Driver/Disable/Uninstall
Gmojo is offline
post #4 of 5 Old 06-06-2012, 05:23 PM
alk3997's Avatar
Liked: 92
Yes it's WIndows 7
What happens when you select the AMD option or the VIA option? Any differences?
alk3997 is offline
post #5 of 5 Old 06-07-2012, 11:09 AM - Thread Starter
Gmojo's Avatar
OK It's working now, thanks.
Gmojo is offline
Reply HDMI Q&A - The One Connector World
