IR Through HDMI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-10-2012, 11:00 PM - Thread Starter
Superfluous's Avatar
I've found that HDMI seems to have many annoying and useless features that screw with the picture settings, sound settings, and turning my TVs and equipment on and off. One thing it could do that would be extremely beneficial would be if it could send IR signals that are shot through the TV back to the receiver and ultimately the components connected through HDMI. Does it do this and I'm just unaware? Could this be in the future?
Superfluous is offline
post #2 of 7 Old 06-10-2012, 11:29 PM
Colm's Avatar
Liked: 94
HDMI doesn't have the ability to carry IR per se. It does have CEC, which allows you to control several connected CEC-enable devices with only a singe remote, say the TV's. Seems to work best when all the gear comes from one manufacturer.
Colm is offline
post #3 of 7 Old 06-11-2012, 10:40 AM
alk3997's Avatar
Liked: 92
I don't think you'll get much argument here about some of the annoyances of HDMI. Most of those annoyances are tied to the requirement to only send out a signal that is fully compatible with every output sink. Originally, much of HDMI is based on sending out a *secure* uncompressed signal at the maximum then-available speed rather than a user-friendly signal.
The CEC option was added in later versions of HDMI and for what it was designed-for, it is a reasonable implementation. However, it is one of those options that I suggest be disabled unless people really want their DVD player starting-up their projector or TV.
While many people agree that these are annoyances, unfortunately none of the folks on this forum are part of the HDMI Org, which mandates much of the HDMI specs. So, other than our understanding I don't think we can offer much in the way of promising any changes.
alk3997 is offline
post #4 of 7 Old 06-11-2012, 12:56 PM
Selden Ball's Avatar
Quoted: 3050 Post(s)
Liked: 1494
Until that future comes, you might want to consider a universal programmable remote, like one of Logitech's Harmony models.
Selden
Selden Ball is offline
post #5 of 7 Old 06-11-2012, 03:03 PM
Colm's Avatar
Liked: 94
+1
Colm is offline
post #6 of 7 Old 06-13-2012, 03:49 AM
Joe Fernand's Avatar
Quoted: 281 Post(s)
Liked: 164
There are ‘dongles’ which can allow you to run IR over an HDMI cable – they aim to use the signal path through the HDMI cable normally reserved for ARC!
They don’t always work and you have to be careful if any of the connected devices support ARC!
As others have said CEC is great when it works but just another problem when it doesn’t!
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is online now
post #7 of 7 Old 06-15-2012, 01:57 PM
ericspencer's Avatar
Vanco make a system that works most of the time!
ericspencer is offline
Reply HDMI Q&A - The One Connector World
