Monoprice RedMere HDMI cables - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
Old 05-28-2014, 01:20 AM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
Originally Posted by obonillaf View Post
I need to buy a 30" Monoprice Redmere HDMI cable. I just can't see what's the difference between these two Monoprice options:
i. 9170 : http://www.monoprice.com/Product?c_id=102&cp_id=10255&cs_id=1025507&p_id=9170&seq=1&format=2
ii. 9430 : http://www.monoprice.com/Product?c_id=102&cp_id=10255&cs_id=1025506&p_id=9430&seq=1&format=2
Any insight would be greatly appreciated. Thanks!
It sounds like the first cable (9170) is thinner than the second cable. I would ask Monoprice support.
obonillaf likes this.
htwaits is online now
Old 05-28-2014, 11:36 AM
obonillaf's Avatar
Quoted: 62 Post(s)
Any clue about the difference? They even have the same AGW number (28). Could it be that the only difference is the design/color?
obonillaf is offline
Old 05-28-2014, 11:45 AM
neocataboi's Avatar
They are exactly the same cable. the only difference will be the form factor and the color. Either will work great.
neocataboi is offline
Old 05-28-2014, 02:11 PM
obonillaf's Avatar
Quoted: 62 Post(s)
Thanks! Ordering right now!
Old 07-04-2014, 02:56 PM
tboe77's Avatar
Quoted: 62 Post(s)
Liked: 136
Not long ago, I switched to the Monoprice super slim HDMI cables with redmere. All 6' lengths. I was not having any issues with my original cables. I simply switched in order to minimize the stress placed on the ports by stiffer, heaver cables.
Even more recently, I came across this thread, over at Audioholics:
http://forums.audioholics.com/forums...ml#post1013847
I'm not having any issues with the redmere cables in my system, but now I'm worried that the power draw of the redmere cables may cause damage to my electronics with long-term use.
Does anyone here know if there is merit to this concern?
Thanks much for any help!
Chronic masticator.
Gear: Speakers (Paradigm Reference Studio Series): 40 v4 (front L/R), CC-690 v4 (centre), 20 v4 (surround L/R). PSA XS30 (subwoofer).
Denon AVR-X4000, Emotiva XPA-5, Samsung PN64F8500 (64" plasma), DarbeeVision Darblet DVP5000, PS4, PS3, Sony BDP-S6200,
Apple TV (3rd gen.), Harmony One, Sennheiser RS180
tboe77 is offline
Old 07-05-2014, 12:06 PM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 853
I don't think long term detrimental effects have been proven. That's the first time I've read of a situation where the actual cable affected the HDMI port. I'd be more apt to think that the HDMI port itself was just on the absolute minimum of current design but it's hard to tell. It is interesting. I use Redmere for the flexibility and they've been fine.
tboe77 likes this.
Otto Pylot is online now
Old 07-08-2014, 03:16 PM
Roberyu's Avatar
Quoted: 18 Post(s)
Liked: 24
Haha, I'm even using these Redmere cables in-line with HDMI devices that have their own significant draw (Gefen HDMI detective, and both cables to and from it are Redmere), and am experiencing no issues after weeks of use. I'll let you guys know if I have any HDMI port failures from this.
I've also have these being used on a 4x4 HDMI matrix (Shinybow), and a Denon receiver (to all source inputs, and out multiple outputs). On the matrix, I have some HTPCs going to Gefen HDMI-Detective, then to the HDMI matrix, then to the receiver, then to the TV (other matrix outputs are going from the HDMI output to a Cat-6 extender (using a Redmere cable too). Were talking entire signal chain incorporating Gefen HDMI detectives, a matrix, a receiver, then TV (and other sources using Cat6) all using Redmere where an HDMI cable would be used. I guess I'm just a "running with scissors kind of guy, haha. I should be at least a canary in the coal mine in regards to this potential issue.
tboe77 likes this.
Roberyu is offline
Old 07-08-2014, 04:15 PM
tboe77's Avatar
Quoted: 62 Post(s)
Liked: 136
Thanks for the responses guys! If anyone else has any input, I'd love to hear it.
Maybe I'm worrying over nothing. However, since I switched to the redmere cables just for the form factor (slim, flexible cable) I decided to see if I could find some super-slim passive cables. I know that Parts Express has them, but the shipping to Canada was expensive. I found some very inexpensive cables from a Canadian vendor that look to be very similar to the ones from PE. I'm going to try them out, just to put my mind at ease. I hate the idea that I might be shortening the lifespan of my TV or receiver by using active cables when passive ones would work just as well.
Chronic masticator.
tboe77 is offline
Old 07-08-2014, 04:34 PM
Otto Pylot's Avatar
Liked: 853
Passive small gauge cables should work provided your runs aren't too long. Just make sure they are certified for the length that you need.
Old 07-08-2014, 04:45 PM
tboe77's Avatar
Quoted: 62 Post(s)
Liked: 136
No, I don't have any long runs. All my cables are 6', and that gives me plenty to work with.
Chronic masticator.
tboe77 is offline
Old 08-07-2014, 12:27 AM
tractng's Avatar
Quoted: 104 Post(s)
Liked: 29
i. 9170 : http://www.monoprice.com/Product?c_i...seq=1&format=2
ii. 9430 : http://www.monoprice.com/Product?c_i...seq=1&format=2
I need to order one of these for a setup in my new home. I assumed it would work with a 1080P projector going to an AVR?
Will be buying the latest AVR very soon.
TT
tractng is offline
Old 08-07-2014, 01:20 AM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
TT
Do you mean 30 feet?
Old 08-07-2014, 08:47 AM
tractng's Avatar
Quoted: 104 Post(s)
Liked: 29
Yes.
tractng is offline
Old 08-07-2014, 10:20 AM
Otto Pylot's Avatar
Liked: 853
The Redmere cables should work fine at 30' for a projector -> receiver setup. Just curious, at 30', how are you going to install the cable(s)?
Old 08-07-2014, 12:41 PM
tractng's Avatar
Quoted: 104 Post(s)
Liked: 29
It is going through a hole on the ceiling and run in the attic. Then it will go down into a closet where I will have a cutout area and built a custom rack there. Similar to what I did in the old house. Too much work but hopefully it will turn out fine. I toss the old 25' hdmi cable away thinking it might not be to spec for the new AVR. Old hdmi was about 6 years ago.
Hopefully this cable is good for years. I might just run conduit to avoid the headache. What are the common size of the conduit?
tractng is offline
Old 08-07-2014, 01:55 PM
Otto Pylot's Avatar
Liked: 853
As a thought you might consider using conduit if you have access to the wall in the closet. You also might want to consider CAT-6/HDBT. That's a bit more expensive but it is easier to repair/replace if you have to and a good CAT-6 cable (or 2) sort of "future proofs" your connection for quite a while. Current, certified high speed HDMI cables can easily handle the new HDMI 2.0 spec (as can CAT-6) but CAT-6 will probably give you a little more "expandability" as specs change over time. Do keep in mind that Redmere cables have a little chipset in the sink end so they can draw some power, and as all electronic devices, can fail over time.
You don't have to run conduit in the attic space (I didn't), only down the walls.
Old 08-07-2014, 02:53 PM
obonillaf's Avatar
Quoted: 62 Post(s)
TT
Yes, I am using these cable to connect my Epson 5030 projector (1080p) to my Denon AVR X-2000 with no problem. Everything flawless.
Old 08-08-2014, 12:22 AM
tractng's Avatar
Quoted: 104 Post(s)
Liked: 29
Thanks for the info.
tractng is offline
Old 08-10-2014, 02:50 PM
bodean's Avatar
Quoted: 170 Post(s)
Liked: 43
Are they Redmere cables? I heard from numerous people via posts that buying a small size (6') of these cables is not recommended, and to only by long sizes. Any truth to this? I am in search for 4 6' hdmi cables to replace what I have, and want the thin
Sony KDL65W850A 65" LED HDTV  || Bose Soundtouch 130 soundbar || Synology DS716+ NAS || XBOX One ||
Xbox Live : BoDEAN
bodean is offline
Old 08-10-2014, 04:11 PM
Otto Pylot's Avatar
Liked: 853
The advantage of Redmere cables is that they are active so you can have runs longer than 25', which is the current limit for certification of passive cables, and still maintain HDMI 1.4 (or 2.0) standards.
Under the 25' limit does not mean that you can't use the cables it's just that it's a bit of an overkill for the cost. If you want thin, flexible cables for under 6', they will work just fine. However, you could probably get by with a thinner gauge certified high speed HDMI cable and be ok. I use Redmere at 10' and 6' and they are just fine.
Old 08-13-2014, 11:00 PM
Plasma5300's Avatar
Quoted: 130 Post(s)
Liked: 24
Im using a sony slim high speed hdmi cable. It is really thin. About as thin as a micro usb charging cable. I dont think it has a chip to draw power. How is that possible that it works being so thin???
Plasma5300 is offline
Old 08-17-2014, 07:43 PM
AV_Integrated's Avatar
Quoted: 973 Post(s)
Liked: 718
It's not possible. You are imagining things. If you still aren't sure though, you should start a separate thread about it.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
Old 08-17-2014, 07:55 PM
Plasma5300's Avatar
Quoted: 130 Post(s)
Liked: 24
Whats not possible?
Old 08-17-2014, 10:27 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
All my short HDMI cables (1.5' - 3.0') are 36 AWG thin passive cables. Passive cables are off topic in a Redmere thread, but you should know that the chip in an active Redmere cable has nothing to do with drawing power. The chip applies amplification to the signal to compensated for the amount of signal lost over the exact length of the cable in use. Passive cables are corrected for the signal lost over a 6' cable.
A 15' passive cable will get less correction than it needs, and a 3' passive cable will get more correction than it needs. Either one may work but the margin for error has been reduced significantly.
Old 08-30-2014, 10:30 PM
steves40th's Avatar
I am using a Redmere HDMI 15 foot cable. On one older LG tv, it cuts in and out. On my 2010 46' Samsung LCD tv I get an red line that flashes occasionally across the TV. Monoprice replaced the cable. Works a little better.
I am feeding the TV's with a Sager NP5160, W7 64 bit 8gb ram and a 540m nvidia laptop video card.
ANy suggestions for a good 20 foot cable that is thin and light like this. Drivers for the Redmere?
steves40th is offline
Old 08-31-2014, 11:32 AM
Otto Pylot's Avatar
Liked: 853
There are no drivers for a Redmere cable. It's just a dumb pipe that sends what ever data it receives, and just happens to have a little bit of electronics in one end to make it active so that you can send that data over longer lengths and with a smaller gauge wire. You can try a smaller gauge passive cable but other than that, it's probably a source issue.
Old 08-31-2014, 11:45 AM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
Nothing that you've posted make it clear that you have a HDMI cable problem.
Old 08-31-2014, 12:02 PM
steves40th's Avatar
So cutting in and out on one tv is not an HDMI cable issue, and red flashes on another isnt a problem? A regular HDMI runs fine. Maybe I should have put that last sentence in there.
Old 08-31-2014, 12:05 PM
steves40th's Avatar
Regular sized HDMI cable, from Wal Mart, and 20 foot thick hdmi cable from Monoprice, works fine. So source is not the issue, in my opinion.
Old 08-31-2014, 12:07 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
You made it sound like one 15' cable was being used for two displays. More information about that or any other details about your HDMI signal path from source to each of your displays would help. The red line flashing doesn't sound like a HDMI problem to me, but more information would be helpful.
