Monoprice RedMere HDMI cables - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #391 of 531 Old 08-31-2014, 11:11 AM
steves40th's Avatar
Originally Posted by htwaits View Post
You made it sound like one 15' cable was being used for two displays. More information about that or any other details about your HDMI signal path from source to each of your displays would help. The red line flashing doesn't sound like a HDMI problem to me, but more information would be helpful.
I tested the 15' redmere on two different displays. Both reacted differently. My laptop runs regular sized cheap HDMI cables to both TV's fine. No issues with video quality. Both TV's were updated with software, to ensure they were up to date. Laptop is a Sager NP5160, very capable laptop for video, I used VLC as the media player.
steves40th is offline
post #392 of 531 Old 08-31-2014, 12:25 PM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2107
Since your setup consists of a lap top and which ever TV you connect using HDMI, is it possible to try the Redmere in another system that doesn't include a computer?
The cutting out problem could be excessive handshake requests caused by your computer, the cable, and or the TV. The red flashing is not something that I've run into in connection with HDMI problems. HDMI technology is a pain at the best of times. If one of your sets is much older than the other that might explain the difference in symptoms.
steves40th likes this.
htwaits is online now
post #393 of 531 Old 09-01-2014, 12:22 AM
steves40th's Avatar
I will try it with a Bluray player when I get home. I am on the road now. Good idea...
post #394 of 531 Old 09-01-2014, 12:49 AM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2107
Also try different HDMI inputs on your TVs. Good luck.
post #395 of 531 Old 09-03-2014, 09:58 AM
rviele's Avatar
Quoted: 173 Post(s)
Liked: 30
hdmi cables
comments would be helped on the audioquest "chocolate" hdmi cable as i'm thinking of getting one.
rviele
rviele is offline
post #396 of 531 Old 09-03-2014, 12:01 PM
Otto Pylot's Avatar
Quoted: 1669 Post(s)
Liked: 1043
Audioquest chocolate cables are grossly overpriced, like Monster. $140 for a 6' cable! Seriously? If a cable is certified by an HDMI.org approved certification agency, then the cable will meet all current HDMI specs, 1.4/2.0. You can't get any better than that. The cable specs may be better in some instances but it's the HDMI specs that are important. Better cable specs doesn't mean you're going to get better audio/video performance if the cable is already certified to meet HDMI specs. Anybody can have a bad cable but a certified $20 cable can perform just as good as $140 cable.
Otto Pylot is online now
post #397 of 531 Old 09-03-2014, 03:27 PM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2107
rviele
If a HDMI cable works it makes no difference who sold it for how much money. I've never used anyones HDMI cables other than Monoprice for out extended family and friends. Just be sure it's "high speed."
post #398 of 531 Old 09-03-2014, 05:29 PM
rviele's Avatar
Quoted: 173 Post(s)
Liked: 30
hdmi cables
do you happen to have the part number from monoprice so that i can make sure i get the right one
thanks
rviele
rviele is offline
post #399 of 531 Old 09-03-2014, 08:59 PM
Otto Pylot's Avatar
Liked: 1043
Just make sure it's a certified high speed HDMI cable certified for the length you need. That's all you need to know. Prices will vary on length and what "extra" stuff they put into the manufacturing (gold connectors, etc) but it's all fluff.
post #400 of 531 Old 09-03-2014, 09:19 PM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2107
Right.
post #401 of 531 Old 09-04-2014, 02:38 AM
Joe Fernand's Avatar
Quoted: 408 Post(s)
Liked: 225
Just make sure it's a certified high speed HDMI cable certified for the length you need.’ – and be wary of folk who claim ‘up to 10m’ (and forget to add 'but not including 10m'!).
Joe
Octava Inc. Multi-cast HD over LAN solutions.
Ruipro UK and EU Sales and Support
The Media Factory. Residential and Commercial system Design, Consultancy, Installation, Supply and Integration.
Joe Fernand is offline
post #402 of 531 Old 09-07-2014, 11:01 PM
tractng's Avatar
Quoted: 144 Post(s)
Liked: 31
Guys,
I bought a 30ft RedMere cable from Monoprice in Aug and finally have a chance to test it out. It doesn't display an image (black screen). Ist this a defective cable? I tried two different bluray players. I did check the source and display end correctly.
Cable I bought:
http://www.monoprice.com/Product?c_i...seq=1&format=2
tractng is offline
post #403 of 531 Old 09-07-2014, 11:43 PM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2107
Originally Posted by tractng View Post
Guys,
Cable I bought:
Are you aware that RedMere cables are directional? You may have installed the cable backwards.
post #404 of 531 Old 09-08-2014, 09:10 AM
tractng's Avatar
Quoted: 144 Post(s)
Liked: 31
I check the correct end. Display goes to TV and source goes to bluray player. Also tried reversing.
tractng is offline
post #405 of 531 Old 09-08-2014, 09:13 AM
Otto Pylot's Avatar
Liked: 1043
Have you selected the correct input? Can you try another cable just as a test in the same input to rule out the input/cable?
post #406 of 531 Old 09-08-2014, 10:17 AM
tractng's Avatar
Quoted: 144 Post(s)
Liked: 31
I have checked with old cable and it worked fine and. Also, tried different HDMI ports. Good thing I have tested or it would been a nightmare running through the wall/ceiling for a projector setup. Is there an alternative cable that will work well for future 4k device without the chip?
I had a 30 ft hdmi cable from monoprice that I bought 6 years ago that worked well but ripped it out when we sold the house. I that time I figured its an old hdmi cable and its time to change . I got an RMA from monoprice but am not sure if I want RedMere now.
tractng is offline
post #407 of 531 Old 09-08-2014, 01:13 PM
AV_Integrated's Avatar
Quoted: 1148 Post(s)
Liked: 825
There is no perfect future-proof cable. The only future-proof solution is conduit.
Some very good solutions are cat-6 cable, or fiber. Both of which can have adapters put in place to transmit HDMI A/V over. Fiber is nearly limitless with how much resolution it can support.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is online now
post #408 of 531 Old 09-08-2014, 01:15 PM
Otto Pylot's Avatar
Liked: 1043
If you're installing the cable in the wall/ceiling I strongly recommend that you use at least a 1" conduit. It makes repairing/replacing cable so much easier. You could install a second cable for future use/need or, at least, a pull string for future cabling. I'm surprised that the Redmere Cable didn't work. It's always possible to get a bad cable from anyone I suppose. HDMI specs will continue to change over time. The current HMDI specs (1.4/2.0) can easily be met with current high speed HDMI cables (there's no such thing as an HDMI 1.4 or 2.0 cable). If you want to "future proof" the best thing you can do now is install solid core CAT-6 cable for that length and use HDBT (HDBase-T) as connectors. Or, you could install a thicker gauge HDMI cable but then you have flexibility issues and strain on the connector ends. Just make sure that what ever you do you don't have any sharp bends in the cable as it transits the wall and attic space.
post #409 of 531 Old 09-08-2014, 03:02 PM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2107
As others have pointed out there is no way to future protect HDMI cables, and any cable can arrive defective. The best you can do is selecting "high speed" and exchange the cable.
You've already checked all your settings and used another cable, so it really does sound like a dead cable. It's always possible but not something that happens very often. I've personally had one 6' HDMI passive cable replaced by Monoprice in the ten years that I've ordered for our extended family. My personal 15' Redmere has been perfect. So was the 28 AWG cable that it replaced.
Good luck.
post #410 of 531 Old 09-08-2014, 07:59 PM
Liked: 0
Are there devices that are just not compatible?
I bought a 10' Redmere cable from Monoprice. I was trying to use it with my Micca Speck Media Player. If I use a regular cable to my TV it works, when I try to use the Redmere, it doesn't. I have it plugged the right way and when I use a blu-ray player it works. I thought the power came from the sink. If that is the case, then the Sharp Aquos TV is the sink and the Speck is the source. What could cause this not to work?
fndecker is offline
post #411 of 531 Old 09-08-2014, 08:17 PM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2107
I assume that you've already done this.
"NOTE From Amazon: If player has no video output, press the "HDMI" or "AV" button on the remote. "
If the Redmere HDMI cable works to connect a Blu-ray player to your TV, but it doesn't work when you connect the Micca Speck to your TV with the same Redmere HDMI cable, then I suspect the Micca Speck. As I understand it, all the Redmere chip is doing is amplifying the signal to compensate for signal loss due to the difference between a 6' cable and a 15' cable.
I don't know sinks from tubs.
You can probably get information from Monoprice or a thread dedicated to the Micca Speck if there is such a thing.
post #412 of 531 Old 09-12-2014, 04:37 PM
tractng's Avatar
Quoted: 144 Post(s)
Liked: 31
Good luck.
I end up getting a non Redmere cable as replacement from monoprice
tractng is offline
post #413 of 531 Old 09-13-2014, 07:03 PM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2107
With HDMI "what ever works" is the byword.
post #414 of 531 Old 09-14-2014, 12:18 AM
dannieboiz's Avatar
Quoted: 73 Post(s)
I read over the threads and it seems some of you ran 50ft cables w/o a problem. Are you guys using any extender/booster in between?
I need a to run a length of 30ft from my Onkyo Reciever to my receiver. Do I need to add any extender?
dannieboiz is offline
post #415 of 531 Old 09-23-2014, 12:46 PM
Liked: 0
I have a similar query. I need to run a 75ft cable in the wall
Can someone suggest if I get this one?
I am looking at a 9To5Cables cables from Amazon
Do I still need an extender?
thanks
atlantabraves2000 is offline
post #416 of 531 Old 09-23-2014, 02:51 PM
Otto Pylot's Avatar
Liked: 1043
75' is a long run even for a thick gauge cable. There is no one, single answer that is going to be correct for you. Lots of good suggestion have already been put forth.
1. Conduit for what ever you do. Period. Just make sure there aren't any sharp bends in what ever cable type you install.
2. Redmere technology (active). A bit expensive.
3. Thick gauge high speed hdmi (passive). Flexibility and bending at that length may be an issue not to mention the strain on the inputs due to cable size.
4. A single, solid core CAT-6 cable (or two for future/other uses) with an active extender (HDBase-T or similar).
Just remember that passive high speed hdmi cables are only certifiable (currently) up to 25'. They will work at longer lengths its just that all HDMI 1.4/2.0 protocols have been tested and certified for up to that length.
post #417 of 531 Old 09-23-2014, 02:59 PM
Liked: 0
Thanks for the detailed explanation.
1) By Conduit you meant putting in a pipe?
2) Unfortunately Monoprice does not sell Redmere with 75ft. I will search for more vendors
3) I know that might be an issue but unfortunately due to room size, this is to be done.
4) I was thinking of avoiding an extender till now but I think I have to go for one in this case
post #418 of 531 Old 09-23-2014, 04:51 PM
Otto Pylot's Avatar
Liked: 1043
1) Yes. Typically a 1" flex-tubing or something similar. If you ever have to repair/replace or update your cable, you'll thank me (us) repeatedly
2) There may be a maximum length for Redmere. I've never researched above what I needed.
3) There are 45 degree/elbow adapters that work quite well so you could connect your cable to that (straight on, but facing downwards for example) and then connect the adapter to the HDMI input. You might even be able to secure the HDMI cable so that it couldn't move the adapter.
4) Active extenders do work but I'm not sure how that would work in-wall.
Joe is good at this stuff so hopefully he'll have some ideas.
post #419 of 531 Old 09-24-2014, 07:40 AM
Liked: 0
Could you suggest your recommendations for the flex tubing and the elbow adapters
Thank you very much.
How should I contact Joe about his views
post #420 of 531 Old 09-24-2014, 10:10 AM
Otto Pylot's Avatar
Liked: 1043
Any flexible conduit tubing will work. I forget what we used because we had an electrician install the conduit while we were remodeling. You can Google for an idea of what is available. The same for the 90 degree or elbow HDMI adapters. Just Search Amazon or Monoprice.
Joe usually cruises this forum and replies quite often. He may show up.
Reply HDMI Q&A - The One Connector World
