Monoprice RedMere HDMI cables - Page 15 - AVS | Home Theater Discussions And Reviews
 3Likes
post #421 of 437 Old 09-29-2014, 02:37 PM
Liked: 0
Originally Posted by Otto Pylot View Post
Any flexible conduit tubing will work. I forget what we used because we had an electrician install the conduit while we were remodeling. You can Google for an idea of what is available. The same for the 90 degree or elbow HDMI adapters. Just Search Amazon or Monoprice.
Joe usually cruises this forum and replies quite often. He may show up.
Will this work if I join two HDMI Redmere cables?
HDMI Keystone Jacks on Monoprice.
thanks
atlantabraves2000 is offline
post #422 of 437 Old 09-29-2014, 05:49 PM
Otto Pylot's Avatar
Quoted: 344 Post(s)
Liked: 296
Probably not because at 75' you still may have signal issues due to length. Why don't you want to run conduit and do something simple like CAT-6 with some sort of active termination? If you're thinking about two lengths of Redmere that wouldn't work because the sink end of the Redmere cable (they are uni-directional) needs a small bit of power for the chipset in that end.
Otto Pylot is online now
post #423 of 437 Old 09-29-2014, 07:51 PM
AV_Integrated's Avatar
Quoted: 413 Post(s)
Liked: 410
Originally Posted by atlantabraves2000 View Post
1) By Conduit you meant putting in a pipe?
Carlon Riser Gard conduit is available from a number of places online in 1" and 1.25" dimensions at 100' lengths. This is a flexible conduit, so it's not like PVC pipe, but more like a vacuum hose. A bit heavier, and rated for in-wall use. Good stuff.
2) Unfortunately Monoprice does not sell Redmere with 75ft. I will search for more vendors
I'm not aware of 75' Redmere cables, but no matter what, there is no promise of it working, and even less promise of long term use and reliability. Either install conduit, or put in two pieces of HDMI and 2 cat-5e or cat-6 cables. I personally ran conduit, and use the Monoprice 75' 22AWG HDMI cable between my basement and the bedroom, and I did have good results in doing so. YMMV. But, I ran cat-5e and I can add cat-6 if I want/need to. At the end of the day, you really want to focus on covering your butt, not on what is cheapest, or what gets you by today. Long term, reliability should be a goal.
Oh - and I run directly from my source to the TV. Long gentle turns on the HDMI cable behind the TV.
3) I know that might be an issue but unfortunately due to room size, this is to be done.
There is no issue with those distances. I've used fiber conversion units to thousands of feet with HDMI. There are solutions, but some of them cost more than others. At over $1,000 per end point, fiber is certainly not something that everyone is going to be doing. But, it's still an ideal solution for some.
4) I was thinking of avoiding an extender till now but I think I have to go for one in this case
I agree. A good HDBT solution is the way to go if you want to keep cabling to a minimum and can't run conduit. Always at least two cat-5e or cat-6 cables as a minimum. This way, if any cable fails, or new standard comes out that needs a bit more bandwidth, you have cabling in place that should protect you for years to come.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #424 of 437 Old 09-29-2014, 09:14 PM
Otto Pylot's Avatar
Quoted: 344 Post(s)
Liked: 296
^^^^^ Excellent advice.
post #425 of 437 Old 10-08-2014, 12:36 PM
Liked: 0
Thank you very much for your advice. Actually I was able to use only 60" Redmere cable only since I now installed the projector on the roof. The conduit was not necessary since the wire is going along the unfinished part of the basement
thanks again for your help both of you
post #426 of 437 Old 10-16-2014, 01:19 PM
plouie10's Avatar
Hi Guys,
Just found these cables and purchased some off Amazon. I originally had some no name ones and found that they didn't work, so I thought perhaps it was because they were no name brand cables. Anyways, I'm hooking devices up to an Anthem MRX-510. I know they are one directional. I have the following devices
AppleTV
Oppo BDP-93 Blu ray player
Arris Cable TV
WDTV Live player
I tried on AppleTV. Worked only the original time, but when I unplugged and plugged back into reroute the cable, would not work. Ended up plugging back in the old HDMI cable.
Tried on Oppo. Wouldn't work at all again.
Tried on WDTV Live, worked okay, but the odd second or so every now and then the picture would blank out but the sound kept playing. Went back to old HDMI cable.
Tried on Arris Cable box. No issues, works great.
Is it just that it works on some devices and not on others? I am only using 6ft. cables. I only wanted to used them to neaten up the look behind the console.
Phil
plouie10 is online now
post #427 of 437 Old 10-16-2014, 01:37 PM
Otto Pylot's Avatar
Quoted: 344 Post(s)
Liked: 296
I use 6' Redmere cables to connect the AppleTV2 and blu-ray player to the receiver and then to the tv. Works perfectly. They should work with any device as they are dumb cables with a little electronic chip at the sink end. Have you tried the one cable that works on the Arris cable box on your other devices and vice versa? That would rule out a physical cable issue.
post #428 of 437 Old 10-24-2014, 07:28 AM
plouie10's Avatar
Unfortunately, no go. That doesn't work either. No big deal. Just wanted to make things neater. Oh well, back to the fat HDMI cables. At least they work fine.
post #429 of 437 Old 10-24-2014, 08:11 AM
Quoted: 413 Post(s)
Liked: 410
Originally Posted by plouie10 View Post
Hi Guys,
AppleTV
Arris Cable TV
WDTV Live player
Phil
Why not use slim passive HDMI cables instead of active ones? There is a chance that the voltage needed to drive the RedMere chips isn't strong enough.
I have tested about 60 of these cables at 1', 3', and 6' lengths without issue using 1080p/60 content on a Quantum tester ($10,000) and they have all worked well.
http://www.parts-express.com/search....le*&PortalID=1
There are other brands out there as well.
post #430 of 437 Old 10-24-2014, 08:19 AM
plouie10's Avatar
Awesome! Thanks! I'll have a look. Didn't know they existed.
http://www.parts-express.com/search....28%29%2Frecord[endeca%3Amatches%28.%2C%22P_PortalID%22%2C%221%22% 29+and+endeca%3Amatches%28.%2C%22P_Searchable%22%2 C%221%22%29]&Ntt=super*+slim*+hdmi*+cable*&PortalID=1
post #431 of 437 Old 10-24-2014, 09:52 AM
Otto Pylot's Avatar
Quoted: 344 Post(s)
Liked: 296
AV_Integrated beat me to it but yeah, use the Slim HDMI cables. They should work fine for the lengths you are running if the Redmere's aren't working for you.
post #432 of 437 Old 01-01-2015, 02:01 PM
FL335i's Avatar
I just installed a 50' monoprice redmere HDMI cable. Lots of issues. Worked great for about 10 minutes, then "format not supported" is flashing across my TV. I've plugged it into the PS3 directly, and into the Onkyo. Works better with the PS3, but still craps out. I tried manually setting the Onkyo to 720, 1080i, 1080p, 1080p/24. NOTHING WORKED. I just emailed their CS. What stinks is this cable is installed in the attic. Yes, I tried it before installing it. Worked. I wasn't going to sit there and watch a whole movie... I ran it for 3 minutes and then installed it. Cable is a POS. So either they tell me I'm a lucky winner that got one of their defective batches and swap it out with a good one, which I'll trial run for a whole day or 2 before I install in the attic... OR I go to a CAT6 setup.
Cable I bought:
http://www.monoprice.com/Product?c_i...seq=1&format=2
63" Samsung Plasma, Onkyo TX-NR5009, Deftech BP-8020 Super Towers, Deftech 8040 Center, Mirage OS3 Surrounds, HSU VTF2-MK4 Sub, PS3 & HD DVR box.
FL335i is offline
post #433 of 437 Old 01-02-2015, 11:53 PM
Liked: 0
Slim Series CL2 vs non CL2
Thinking of buying a 40ft monoprice hdmi cable. Can anyone suggest if I should with
40ft High Speed HDMI® Cable w/ RedMere® Technology - 9431
or
40ft Slim Series CL2 High Speed HDMI® Cable w/ RedMere® Technology - 9171
Both are redmere. Except one is CL2 certified. Both have been in the market for the same time. The one that is not CL2 has more reviews and so I think is more popular. I see people have been using the non-CL2 hdmi cable for in wall use also. I will be routing the cable via conduit pipe from receiver to projector. I think the thickness of both cables is the same.
rkothapa is offline
post #434 of 437 Old 01-03-2015, 10:02 AM
Otto Pylot's Avatar
Quoted: 344 Post(s)
Liked: 296
At that length you might want to consider CAT-6 -> HDBT. I only say that because the Redmere cables are active cables in that they have a chipset in the sink end. Like all electronic devices, the chipset can fail over time. Mine haven't, but they are short runs and are easily accessible behind the HTS. CAT-6 will probably never fail because it's just wire, only the outside termination is powered but that's outside the wall. It would be much easier to fix a termination end than to pull 40' of cable out and replace with same. Just a consideration. What ever you do though, I'd lay it out on the floor first and test before installing it. Just in case.
post #435 of 437 Old 01-03-2015, 10:57 AM
Joe Fernand's Avatar
Quoted: 58 Post(s)
Liked: 74
'I will be routing the cable via conduit pipe from receiver to projector. I think the thickness of both cables is the same.' - it's not the cable diameter you have to worry about it's the HDMI Connectors and how you plan to 'pull' the cable without potentially separating the Connector from the cable stock!
CAT6 + HDBT Extenders every time
http://www.octavainc.com/HDMI_extender_HD70STPEX.html
Joe
If I've helped 'Like' me on Facebook - www.facebook.com/Octavainc
Joe Fernand is offline
post #436 of 437 Unread Today, 07:34 AM
John Stockton's Avatar
I did not read through all the pages so forgive me if this has been asked before. I want to know if Monoprice plans to have the Redmere 18 Gbps HDMI cable for lengths greater than the available 15 ft ??
The run from my source to the projector is around 25 ft and I was really hoping the 18 Gbps HDMI cable would be available for that.
John Stockton is offline
post #437 of 437 Unread Today, 04:45 PM
Otto Pylot's Avatar
Quoted: 344 Post(s)
Liked: 296
Any reason why you don't want to go with solid core CAT-6 and then some kind of HDBT extender to terminate? And no, I don't know what Monoprice's plans are for extending the Redmere technology to longer than 15'. I thought there were Redmere cables at longer lengths, albeit a bit pricey.
Reply HDMI Q&A - The One Connector World
