Monoprice RedMere HDMI cables - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #451 of 531 Old 05-03-2015, 09:48 AM
Otto Pylot's Avatar
Quoted: 1363 Post(s)
Liked: 854
Originally Posted by pixelation View Post
I have a 15' (non-monoprice) Redmere cable that works fine. Now I see the monoprice is having a sale on the Redmere so I bought a 3'.
Yes, 3'. I think worse case I use it as a backup. But what I was thinking was that what if I cut the 3' Redmere in half and then extend them. I can make arbitrary length Redmere cable.
I guess I can terminate them into 2x RJ-45. This is more of an experiment. Thoughts?
As mentioned, that won't work. Re-wiring an HDMI cable is difficult enough but an HDMI cable with Redmere technology is virtually impossible. They are uni-directional cables. In other words, the sink end (tv side) has a chipset in it so that a little power can be drawn which allows the cables to be run at longer distance than the current 25' maximum for certified passive high speed HDMI cables and use a thinner gauge wire.
Otto Pylot is offline
post #452 of 531 Old 05-04-2015, 04:10 PM
Joe Fernand's Avatar
Quoted: 283 Post(s)
Liked: 167
'I guess I can terminate them into 2x RJ-45. This is more of an experiment. Thoughts?' - we all await the Outcome of the Experiment
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is online now
post #453 of 531 Old 05-04-2015, 06:20 PM
pixelation's Avatar
Originally Posted by ScottJ View Post
Not likely to work. The electronics in the Redmere cable are tuned to the specific cable length. Even if that wasn't the case, splicing HDMI will change the electrical characteristics of the cable enough that the signal likely won't pass through correctly any more.
I wasn't aware that the redmere chip is tuned to the specific cable length. If that is the case, my experiment of arbitrary length Redmere HDMI won't work.
pixelation is offline
post #454 of 531 Old 06-15-2015, 11:04 AM
MAYBEN's Avatar
Liked: 0
HDMI 15' and 4'
I'm redoing some re-wiring for my Dad. I originally bought him CL2 HDMI cables from Knukonceptz @ 8' each.
We've changed the set-up and the 8' are too stiff and lengthy for connecting the STB and Blu-ray to the AVR, so I'll likely be using 4' cables so that I can still route them nicely. Regarding the cable from the AVR to the TV, we need a little more length, around 12'.
I've seen many threads recommending running HDBaseT and whatnot, but it doesn't seem necessary for the near future as we're just going from behind the TV, into the wall, down, then out to the AVR, decently 'short' run. Plus, he wouldn't need to buy the other equipment needed. Other recommendations I've seen include using the Monoprice Redmere and the Ultra Slim Non-active for the 4' cables.
What's the latest and greatest suggestions for what I'm trying to do?
2x 4'
1x 12'
MAYBEN is offline
post #455 of 531 Old 06-15-2015, 11:55 AM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1028
Monoprice should be able to provide an HDMI cable for your needs. At 4', 8', or 12'... I wouldn't be overly concerned.
Ratman is offline
post #456 of 531 Old 06-15-2015, 12:49 PM
MAYBEN's Avatar
Liked: 0
I'm more concerned about which specific model to get for the 4' and 12'. The 12' needs to be in-wall rated (I believe) and the 4' does not.
Monoprice has wicked cheap cables and some that are twice as much.
MAYBEN is offline
post #457 of 531 Old 06-15-2015, 12:52 PM
AV_Integrated's Avatar
Quoted: 978 Post(s)
Liked: 721
Originally Posted by MAYBEN View Post
2x 4'
Two of these...
http://www.monoprice.com/Product?c_i...seq=1&format=2
1x 12'
One of these...
That last one is directional, so install it the proper direction.
No wall plates may be used. Directly from source to receiver, then from receiver to display.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #458 of 531 Old 06-15-2015, 01:13 PM
MAYBEN's Avatar
Liked: 0
Originally Posted by AV_Integrated View Post
Two of these...
One of these...
Thanks! for the 12', it is running from the TV into the wall, then out to the receiver. Should this be in-wall rated?
(I can't post/quote links yet!)
MAYBEN is offline
post #459 of 531 Old 06-15-2015, 02:40 PM
Quoted: 978 Post(s)
Liked: 721
If it's a short run in the wall, then ... well yes. But, that's rarely an issue over such a short distance in the wall, in the same cavity in the wall. It's not anything like a 100' run through a common open air handling space. That is, even though this isn't technically proper, it's also something tons of people do, and not a high voltage/electrical cable. There is some discussion through this thread about the legality of running Redmere cables through walls. I personally wouldn't sweat a 5' run through a wall.
post #460 of 531 Old 06-15-2015, 07:33 PM
Otto Pylot's Avatar
Liked: 854
+1
post #461 of 531 Old 08-01-2015, 06:52 PM
hdmi4ever's Avatar
Quoted: 18 Post(s)
I'm considering buying a 60-foot Redmere cable to run from my AV receiver to a projector on the other side of the room. The straight-line distance between receiver and projector is under 20 feet, but I'll need at least a 60 foot cable because it will have to snake around the edges of the room.
My concern is that it that there are so many layers of indirection in my setup for the HDMI signal, and I wonder if the Redmere will have a problem with it.
I want to set it up like this:
[Blu-Ray]-->[AV receiver]---Redmere cable--->[4x1 HDMI switch]--->[HDMI 1x2 splitter]--> [projector]/[TV]
Currently I have the Blu-Ray player on the same side of the room with the projector and directly plugged into the 4x1 HDMI switch, and I use another device to transmit the audio wirelessly back to the receiver, but that prevents me from using the high-bitrate audio tracks on the Blu-Ray discs. The above setup would let me take advantage of the HD audio, but with the Redmere going from one switch (the receiver) into another switch rather than into a display, should I expect that to be a problem?
EDIT: I ended up ordering the cable anyway, but I'll delay running the raceway for it until I see that it works with my system. I'll come back here to report my experience with it.
hdmi4ever is offline
post #462 of 531 Old 08-09-2015, 05:45 AM
rxcats's Avatar
Quoted: 14 Post(s)
I am currently using Monoprice Ultra Slim Series High Performance HDMI® Cable w/ RedMere® Technology cables with my home theatre set up and they work fine. None of my cables are over 6 feet, but I wanted the flexibility of thin cables so I opted for these. I have a OPPO BDP-103D Universal 3D Blu-ray Player (Darbee Edition) on order that will arrive by mid-week and will be changing my set up. I will be routing everything (TiVo Roamio, Apple TV, Roku) through an HDMI switcher then to the new BDP to take advantage of the audio and video processing functions afforded by the BDP-103D. The BDP HDMI-out will then be routed to the HDMI-in on my Vizio S5451w-C2 5.1 Sound Bar and the HDMI-out from the sound bar routed to the HDMI-in on my Samsung HDTV. The thing I am concerned about is if the active RedMere cables will work with this set up or I need to change to passive cables. I noticed on the Monoprice website that there is a disclaimer saying that only one active cable can exist in a single cable run even if using a switch, splitter or matrix; do I need to get some passive cables?
rxcats is offline
post #463 of 531 Old 08-09-2015, 10:17 AM
Otto Pylot's Avatar
Liked: 854
To both of you, keep in mind that the Redmer's are active in that they draw a little power from the sink end (tv side). You may encounter issues running thru switches, etc because of that. Redmere cables can't, or shouldn't, be daisy-chained with another active or passive cable. I think Monoprice put up that disclaimer because they were getting too many returns for that very reason.
For runs that long, a lot of folks do in-wall installations using solid core CAT-6 and some sort of active termination like HDBT, but that can be a bit pricey. Even if you don't, or can't do an in-wall installation, CAT-6 is an alternative or a thicker gage HDMI cable with active extenders.
post #464 of 531 Old 08-09-2015, 06:40 PM
hdmi4ever's Avatar
Quoted: 18 Post(s)
The 60 foot Redmere cable worked well for the purpose of transmitting audio and video from the receiver and through the HDMI switch, but it introduced a ground loop hum which persisted even when the HDMI switch was set to a local source that didn't use the Redmere cable. Apparently there doesn't exist any HDMI ground loop isolators, so I'll send it back unless I find some other solution soon.
post #465 of 531 Old 08-11-2015, 05:43 PM
rxcats's Avatar
Quoted: 14 Post(s)
I got the following response from Monoprice today which my be helpful to others:
"Thank you for contacting Monoprice Support. Glad to see your interest in our products.
For the kind of set up you are planning to set up, Unfortunately I would not recommend using any active Redmere cables. Redmere cables will only be compatible when connected directly between a source device and a display, it will not work if you are using any kind of adapter or device between them. So connecting them through so may different devices and connections would not be compatible with the active chipset of the Redmere cables.
For the majority of the connections it would be best to use passive High Speed HDMI cables to complete the connections up to the Oppo device, then use the Redmere cable for the output of the Oppo directly to the TV. So long as the Redmere is the last in the run from a source device to the TV/display, the Redmere should work just fine. You just cannot use it when connecting two different source devices or connecting through a switch/splitter device."
rxcats is offline
post #466 of 531 Old 08-22-2015, 10:46 PM
bearxor's Avatar
So I've just had a really crappy Redmere experience.
I ordered a 50ft cable to replace my 25ft and two 6 foot couplers so I could have one run going from my AV receiver to the projector.
Cable came in and, like a good little boy, I tried it first going straight from my AV receiver to the projector with snaking it. No signal. Great, I'll deal with it later. Replace it with the cables that were run previously and no signal... WTF... It was working just a few moments ago.
Tried every combination I could think of with my old cables and nothing worked. Only hooking the cable directly up to the output device and bypassing the receiver worked fine. Fine, whatever, I'll hook an optical audio cable from the Xbox to the receiver and deal with it next weekend.
Next weekend is this weekend. The receiver recognizes that something is plugged in to it when I select an input but all I get is a blue screen on every single HDMI input.
Go and buy a new receiver... Existing wiring works fine. Hook Redmere up from receiver to projector and nothing. Hook it up to a source directly, like an AppleTV or FireTV and nothing.
At this point, I'm convinced something the cable did fried the HDMI input board on my old AV receiver. This $50 cable has now cost me $500.
bearxor is offline
post #467 of 531 Old 08-23-2015, 09:40 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
As like others here Redmere can introduce problems that you don't see with regular HDMI cables.
I purchased a 3 foot Monster (Redmere) cable to use with my new Tivo Roamio OTA DVR. No real reason to use Redmere just purchased on a whim to try, I guess I liked its slim form factor.
The Redmere ran from the Tivo directly to my Denon AVR. From the Denon it went to a Darbee Darblet then to a splitter which feeds my plasma HDTV and front projector.
The Redmere chipset caused the Darblet to reset to its factory setting 4 times usually with a purple screen as it loses the handshake. This has happened over the course of 2 months so the Redmere functioned fine for most of the time...but would then cause the reset when switching modes on Tivo.
I replaced the Redmere cable with a regular 3 foot Ultra Thin HDMI cable and have had no problems since.
Fortunately no horror story like 'bearxor'.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #468 of 531 Old 08-23-2015, 10:13 AM
Otto Pylot's Avatar
Liked: 854
The most reliable connection for a cable with Redmere technology is a direct connection, That is source -> cable -> sink. No switches or any intermediary devices. Because the sink end draws a little power via the chipset there can be issues but as to damaging equipment, I'm not sure about that. The current draw is extremely small. If your run is under 25' a Redmere cable can be an overkill because as noted above, a high speed passive HDMI thin factor cable will work just fine in most cases, and be cheaper. If you absolutely have to run an HDMI cable over long distances the Redmere would be the way to go keeping in mind the connection issue (direct) and the directionality of the cable. Otherwise a thicker gauge cable with some sort of active termination may be in order.
post #469 of 531 Old 09-01-2015, 10:04 PM
qwerty_88's Avatar
Quoted: 60 Post(s)
there a new redmere 50ft hdmi cable.
specs say it can do 18gbps and 4K@60Hz. previous version is only 10.2gbps.
anyone has tried this?
qwerty_88 is offline
post #470 of 531 Old 09-02-2015, 10:15 AM
Otto Pylot's Avatar
Liked: 854
Carefully read the specs. CL2 is in-wall fire rating so that has nothing to do with performance.
"Up to 4k@60Hz" depending on length and cable gauge. That doesn't necessarily mean that at 50' you're going to be able to push 4k@60Hz. Probably but I would specifically ask if that's your goal, and get it in writing.
"Rated 18Gbps for lengths up to 50', these cables are certified to accurately transmit all of the features supported in the latest HDMI specification." What does that mean? Are they certified to 50' at 18Gbps or is that for certain lengths? HDMI 2.0 has lots of specs, quite a few aren't yet in consumer devices and some may never be (just like HDMI 1.4). I wouldn't worry about the 18Gbps sales pitch unless you have devices that can transmit at that bandwidth. Current passive high speed HDMI cables can do 4k@60Hz but is limited somewhat to bit depth.
There's nothing wrong with that cable. $60 for 50' is still a bit pricey though. I would look at how you want to install that cable and then review your options.
post #471 of 531 Old 09-02-2015, 10:21 AM
dalto's Avatar
Quoted: 1239 Post(s)
Liked: 633
I have been testing a couple of monoprice's shorter redmere cables that claim to support 18Gbps and in my testing have been unable to pass a 4K 4:4:4@60Hz signal through them.
The pass a 4K 4:4:4@30Hz signal no problem.
dalto is offline
post #472 of 531 Old 09-06-2015, 02:24 PM
reallynotnick's Avatar
Quoted: 343 Post(s)
Liked: 227
And I assume you are able to pass 3840x2160p 4:4:4@60hz just fine when you swap it out for a different cable? Also I assume you are of course using 8bit color?
reallynotnick is offline
post #473 of 531 Old 09-06-2015, 06:27 PM
dalto's Avatar
Liked: 633
Yes, all those things are true.
In further testing one of the group I bought does pass that signal fine so I am not sure what to make of that. Clearly, two of the cables are not up to spec somehow. I guess I need to call Monoprice.
dalto is offline
post #474 of 531 Old 09-06-2015, 07:44 PM
Quoted: 343 Post(s)
Liked: 227
Thanks! I just wanted to make sure as I was thinking of getting the 25ft 18Gb/s Redmere cable, but I'd hate to spend that kind of money on a cable if they didn't work.
Odd that one works and the other doesn't. Hopefully the one is just a fluke.
post #475 of 531 Old 09-06-2015, 08:03 PM
Otto Pylot's Avatar
Liked: 854
Any cable mfr will have a bad cable every now and then but if you stick with the "big three", Monoprice, Blue Jeans, or MediaBridge you really can't go wrong.
post #476 of 531 Old 10-06-2015, 02:20 PM
LennDawg's Avatar
Quoted: 26 Post(s)
Was wondering if this cable would work for the run in my wall. Going from my TV, down the wall, across my basement ceiling, into my Denon receiver. Will these directional cables work going into my receiver? If you guys don't suggest this cable, could you give me something that will work for me in this setup? I need 50-60ft. Don't necessarily need a 4k capable cable, but would be nice to have it for the future.
LennDawg is offline
post #477 of 531 Old 10-06-2015, 04:31 PM
Otto Pylot's Avatar
Liked: 854
At 50-60' you would probably need an active cable such as one with Redmere technology, but I don't know if they run that long. A heavier gauge passive HDMI cable would probably work but the loss of flexibility and increased strain on the inputs is something that needs to be considered. For "future proofing" I'd run a solid core CAT-6 and terminate it with something like HDBT. A bit expensive but at that length your options are limited even if you don't want/need 4k/60. What ever you do, at that length I HIGHLY RECOMMEND CONDUIT. Didn't mean to shout but that's the only way to future proof and make cable repairs/replacements etc easy to do.
If you are considering using ARC I don't believe that ARC is doable at that length on an active cable.
post #478 of 531 Old 10-11-2015, 09:58 PM
johndoejohndoes's Avatar
Quoted: 153 Post(s)
I need a 10 Foot HDMI Cable that's In-Wall Rated (CL2) and I'd like to get 4K (with 18Gbps) but I don't think that's an option.
I'm settling on these - http://www.monoprice.com/product?c_i...seq=1&format=2
But I read the CL2 isn't printed on the cable. I'll need CL2 printed on the cable to pass inspection.
Can anyone confirm?
johndoejohndoes is offline
post #479 of 531 Old 10-18-2015, 10:07 AM
Quoted: 97 Post(s)
I need to connect my projector to my receiver, can anyone recommend the proper HDMI cable? Would it be the Redmere everyone is referencing above ?
BleedingBlue is offline
post #480 of 531 Old 10-18-2015, 10:13 AM
Ratman's Avatar
Liked: 1028
Perhaps.
How long does the cable need to be?
Ratman is offline
Reply HDMI Q&A - The One Connector World
