New House - Component Cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-25-2012, 10:49 PM - Thread Starter
natter's Avatar
I just moved into a house and the previous owner installed a component cable from the closet in the bonus room to where the tv goes. It goes into the wall and somehow makes it out by the tv. My first idea was going pull that component cable out and replace it with two HDMI cables in case one goes bad.
After playing with it, I realized that this task was going to be a lot harder than I originally thought. So, my next choice is trying to purchase a HDMI --> Component from my Sony receiver to the Sony TV and just use the component inputs on the TV.
Should I go for the $40 converter? http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10114&cs_id=1011410&p_id=8125&seq=1&format=1#largeimage
I'm just worried the picture quality will look like crap.
Thanks for any replies,
Eric
natter is offline
post #2 of 4 Old 07-26-2012, 01:01 PM
alk3997's Avatar
Liked: 92
I think if you read through their customer reviews, you'll get a pretty good idea of what the picture will look like.
Usually these devices don't stay on the market long. This may be surviving because it can't do 1080p (although 1080i/720p are still protected modes).
alk3997 is offline
post #3 of 4 Old 11-19-2016, 06:43 AM - Thread Starter
natter's Avatar
Originally Posted by alk3997 View Post
I think if you read through their customer reviews, you'll get a pretty good idea of what the picture will look like.<br><br>
Thanks for the reply. I went with the monoprice unit and it worked good for a while but finally ended up just stringing in a pair of HDMI cables. Seemed to have a better picture and sound.
natter is offline
post #4 of 4 Old 12-08-2016, 04:22 PM
Liked: 2
Good choice. I always ask myself what's the effort/cost in wiring in the right type of cable.
Will
wkhan69 is offline
Reply HDMI Q&A - The One Connector World
