Good HDMI Splitter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-14-2012, 01:56 AM - Thread Starter
FragZero's Avatar
I'm still having some issues with my NAD 747 + PS3/XBOX. I'd like to fix this using a HDMI splitter + connector box.
I found the setup of a forummember.
Offcourse i have seen the cheap HDMI splitter boxes but they all seem to suffer the same issue - no EDID spoofer so i would lose surround (since my projector does not allow anything it). Unfortunately i can't get the proven-working splitter. (I'm from Europe).
I'm looking for the best way to do this setup.
A splitter + switch box as above - disadvantage is 2 more devices in the wiremess behind my reciever.
A Matrix 4x2 - but can matrix switches be used as a splitter - or is it one output only?
An alternative solution would be to grab a dvdo edge - it has an audio only output and 5 inputs + i currently use an iscan hd which could be replaced (and sold to cover the difference)
Is there a reliable European site to order these parts? Currently i can't seem to find any site which specifies edid spoofing etc.
FragZero is offline
post #2 of 5 Old 09-14-2012, 08:22 AM
Jacek Soszynski's Avatar
I use this one: nSplitter Pro QS. It seems to do everything what you need.
FragZero likes this.
Jacek Soszynski is offline
post #3 of 5 Old 09-17-2012, 12:47 AM - Thread Starter
FragZero's Avatar
Thanks! Thats exactly what i need + i can get it in Europe.
FragZero is offline
post #4 of 5 Old 09-18-2012, 02:13 AM
Joe Fernand's Avatar
Quoted: 281 Post(s)
Liked: 164
A 4x2 Matrix with EDID Management will allow you to set the Source devices to the audio stream you want to send to your AVR.
What’s the problem you are encountering with the NAD AVR?
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is offline
post #5 of 5 Old 09-18-2012, 07:37 AM - Thread Starter
FragZero's Avatar
http://www.avsforum.com/t/1425573/issues-with-nad-747-and-different-hdmi-sources
Here is my earlier topic - still having these issues. I dont mind but my housemates do so i would like to fix this!
FragZero is offline
Reply HDMI Q&A - The One Connector World
