Audio delay with monoprice switch and HDMI cables - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-03-2013, 01:13 AM - Thread Starter
bengalfreak2's Avatar
I did a thread search but couldn't really find the answers I was looking for.
I am trying to power two different Samung LCD TV's (one in the family room and one in the kitchen). My input sources are a DirecTV HR24 DVR and a Samsung BDP - C5500 blue ray. I am connecting them, via standard (cheap 6') HDMI cable to a Monoprice.com 2x2 HDMI switch/splitter. From there I am again using a cheap 6' HDMI cable to a HDMI wall plate also bought from Monoprice. Inside the wall is a 25' 22AWG high speed cable from monoprice which connects to another HDMI wall plate and a 6' cheap HDMI cable from the wall plate to the kitchen tv.
The family room TV is fed by a cheap 6' HDMi from the switch/splitter to the tv.
Here's the issue, the kitchen and family room tv's are fairly close to each other and are on at the same time. There is a slight, but noticeable audio delay when both TV's are going. Is it probable that replacing all of the cheap HDMI cables with 24AWG high speed cables will eliminate by delay problem? I don't want to spend the extra money if its not going to fix the problem. Also, could the wall plates themselves be adding to the delay?
bengalfreak2 is offline
post #2 of 3 Old 02-03-2013, 06:59 AM
alk3997's Avatar
Liked: 93
The answer to your question is "no, a new cable would not help."
You could answer this yourself in two ways,
1) If you work out the speed of an electrical field in a wire and then take the length of the difference between the cables going to one TV versus the other, you would have your answer. The speed of an electron is slow but the speed of the electrical field is quite "zippie" (close to the speed of light). The difference between the two TVs is 31' feet of cable. The distance in the wall plates are even smaller. It works out to be approximately 0.00000003 seconds difference (30 nano-seconds). You'll have to trust me that the speed of sound once the sound leaves the TV is much much much much much much much slower than this.
2) The other way you can prove this to yourself is to add another 31' of cable to the other TV as an experiment. But that seems unnecessary.
Assuming both TV's audio and video are synchronized when watching just that single TV (and you would know that by watching and listening to each TV independently), then the likely causes of your audio differences are 1) the speed of sound and 2) the delay in the different processing chips that convert HDMI from digital to analog in the different TVs. "Real time" really isn't real time with digital processing. There is always some delay and that delay can vary based on the chips used. It's exactly like asking why two computers don't process at the same speed. The HDMI converter chips are processors that read digital inputs and then output an analog video and analog audio signal that your TV's LCD or speakers can use.
Not sure you are going to find a way around this without spending more money. What you would have to do is to find a way to "slow down" the TV that is ahead. Many higher end AVRs have the capability to do that over HDMI. You could add a switch to one TV only and hope that the amount of delay is just what you need (unlikely).
Only "free" things you could try is to disable the HDMI lip-sync option in the TV but your problem is that whatever you do to one TV, the source will supply to both since any source can only send out one audio and one video stream at any time. Or you could make the speed of sound your friend and move the TVs so that the distance from each is just the right distance so that the two audio outputs are heard at the same time.
Also don't get hung up on "cheap" - you used the word 4 times in your three paragraphs. Just because an HDMI cable is "cheap" doesn't make it bad (or good). If you aren't get obvious defects in your picture, then replacing a "cheap" cable with a more expensive cable will just replace the original bits with exactly the same bits. And, again, the cable has no mechanism to hold onto the bits (as they are represented by the electrical wave). Those bits just travel freely from one end of the cable to the other.
alk3997 is offline
post #3 of 3 Old 02-03-2013, 01:09 PM
Joe Fernand's Avatar
Quoted: 374 Post(s)
Liked: 215
As Andy say this is going to be TV processing – disable all video ‘enhancement’ modes on the Two TV’s and see how it goes.
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
The Media Factory. Residential and Commercial system Design, Consultancy, Installation, Supply and Integration.
Joe Fernand is offline
Reply HDMI Q&A - The One Connector World
