Wirelogic HDMI cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 02-16-2013, 08:54 PM - Thread Starter
aaranddeeman's Avatar
Quoted: 1695 Post(s)
Liked: 607
Today I saw at my local Costo that they are selling the wirelogic HDMi cable (2 pack versions).
These cables are marked with arrows for source and sink.
Not sure if they use Redmere technology.
They are pretty thin and I was skeptical if I can connect the 12 ft pair using a coupler in between for my requirement of approx 25' high speed HDMI.
Anyone using these cables? what is your experience?
aaranddeeman is offline
post #2 of 27 Old 02-16-2013, 10:59 PM
Colm's Avatar
Liked: 94
Nope, no Redmere, just a dumb cable.
Two high speed cables connected in series do not necessarily yield a high speed cable of longer length. Two extra sets of connections don't help the signal either.
If you want to live up to your handle, get a 25' certified high speed HDMI cable.
Colm is offline
post #3 of 27 Old 02-17-2013, 04:34 AM
jnabq's Avatar
Liked: 39
If your running 3d, I wouldn't go less than a 22 awg or a red mere.
jnabq is offline
post #4 of 27 Old 02-17-2013, 06:49 AM
Mr.G's Avatar
Quoted: 711 Post(s)
Liked: 397
WireLogic explains their products with arrows as:
Q: What are the arrows on WireLogic HDMI cables for?
A: All conductor metal is directional in nature, which is very audible. Directionality is established by the grain structure formed when raw metal is processed to create conductors. Audio always sounds best when the signal travels with the grain structure rather than against it. All WireLogic HDMI cables are tested for directionality and the connector plugs are labeled with arrows indicating the best sonic performance path. The arrows will point away from the source component (like a Blu-ray player or HD cable box) and toward the display or AV receiver.
http://www.wirelogic.us/hdmi-faqs/
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is online now
post #5 of 27 Old 02-17-2013, 07:47 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 109
The arrows may or may not be true with an analog signals but with a digital signal I don't buy it, sounds like Barnum and Bailey stuff to me. There are manufactures that put arrows for directionality on the audio cables and that has to do with picking up hum and it's really a ground that takes the hum back to the source. Acoustic Reacher is one that uses this on there hi end analog audio cables. Take a look at blue jeans cable they have one of the better information sections on cable construction and materials.
I have 22 gage monoprice cable 25 feet long plus the monoprice port savers and wall plates with 3D and no problems.
Phil17108 is offline
post #6 of 27 Old 02-17-2013, 08:34 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 109
Postscript
There is one HDMI cable that I know of that is directional, that is the RedMere cables from Monoprice and thats because of a chip in them.
post #7 of 27 Old 02-17-2013, 09:16 PM - Thread Starter
Liked: 607
I thought so too why would it matter (direction) for digital signal? Seems all BS what they have..
The only problem is the 22AWG is like a rock and I will need to turn it 90 degree at two places that is gonna be hard. So I was looking for thinner cable. It seems Redmere is the only option for now
post #8 of 27 Old 02-18-2013, 12:44 AM
Colm's Avatar
Liked: 94
You need to observe the minimum bend radius for any cabe you use. It varies from cable to cable, but 3" is in the ballpark for a 22 AWG cable. Bending tighter than that will upset the geometry and affect performance. Thinner cable will typically have a smaller minimum bend radius. A tight 90 degree turn is not good for any HDMI cable.
Colm is offline
post #9 of 27 Old 02-18-2013, 10:21 AM
alk3997's Avatar
Liked: 93
As pointed out previously, this is snake oil. I suspect they put that on the cables so that people don't call the 800 number to ask which way the cables go.
Remember it must be listed as a High Speed cable for it to be a high speed cable and it must be certified. Don't know the price but I suspect you can still get a certified High Speed cable for less than this 2 pack if you search the web. The thinnest long-distance high speed cables I've seen are the Redmeres.
The thing to remember for the directional argument for digital cables is that if you are getting no bit errors then improving the cable does what? The 1s can't be any straighter nor the 0s any rounder since you are getting no bit errors. So, that's snake oil. It's a big difference between analog and digital worlds. Of course an HDMI cable has no "sonic performace" - they are bits traveling through the cable and not analog audio.
If you are getting bit errors then you'll see them very obviously on your screen. No doubt when you see one. Then it's time to look at an improved cable.
alk3997 is offline
post #10 of 27 Old 02-18-2013, 08:13 PM - Thread Starter
Liked: 607
I see ya..
This 2 pack costs $29.99 at costco. So not too much on pricey side like monster.
The manufacturer replied saying direction is for best audio and nothing else. It will work even other-wise. They also imply that as long as you do not exceed 8 meter, interconnect is fine etc etc..
Anyways it was blind shot. I first thought they were selling Redmere... But oh well..
post #11 of 27 Old 02-19-2013, 05:18 AM - Thread Starter
Liked: 607
I see ya..
Just found out out they have 25' cable as well (for $40 at costco.com). They claim the cables are certified high speed for the length it is available.
Just thinking, being costco it's easier to return in case the cable turns out to be not so good..
post #12 of 27 Old 02-19-2013, 05:58 AM
SAM64's Avatar
Liked: 78
No it's not...conductors are not diodes.
The rest of it is just garbage.
SAM64 is offline
post #13 of 27 Old 02-19-2013, 08:54 AM
alk3997's Avatar
Liked: 93
I see ya..
The fallacy of the audio argument is for HDMI the audio bits are in the same stream as the video bits. So, unless the cable were smart enough (which it is not) to discriminate between the audio bits and video bits, both video and audio are treated the same. They are just 1s and 0s (or the electrical representation of 1s and 0s).
However, it doesn't hurt to try since you can return the cable. You'll know if you hit bit errors. However, the price is more than Monoprice would cost.
About the only thing you won't be able to guarantee is whether the cable will handle the maximum bandwidth for HDMI. With 1080p/60 (and lower such as 1080p/24 2D and 3D), you aren't using the full bandwidth of HDMI. Add in Deep Color and you're using some more bandwidth. So as long as you don't care if you can use additional capabilities later, you should be OK just trying the cable with 1080p/60 and Deep Color enabled to see if these cables are good enough.
alk3997 is offline
post #14 of 27 Old 02-19-2013, 06:36 PM - Thread Starter
Liked: 607
I really don't care about the audio and kinda ignore what they are saying. However the manufacturer is very responsive and patient. I am impressed with their response. I will share some excerpts below.
all HDMI cables up through 25ft (7.62m) currently made by WireLogic meet or exceed the 10.2 Gbps maximum current data rate for HDMI. These cables are tested and certified by HDMI Licensing, LLC as High Speed with Ethernet
8 meters is the official limit for High Speed rating. Hence, we would not claim High Speed rating beyond that authorized by HDMI LLC
WireLogic HDMI cables are guaranteed to deliver 100% of the information from the source to the device. We hand test each and every HDMI cable on a Bit Error Rate machine in post-production to assure the same.
post #15 of 27 Old 02-19-2013, 06:40 PM - Thread Starter
Liked: 607
As for monoprice the 30ft redmere is close to $55 shipped. I am avoiding the 22AWG non-redmere for it's bulk.
Wirelogic 25' at costco is $40. I am not in a rush and if a coupon comes by (just a chance) then it might be in the ball park of $30
post #16 of 27 Old 02-19-2013, 09:22 PM
alk3997's Avatar
Liked: 93
I'll give credit where it is due - the response about the 25 foot cable is a reasonable response. Sounds like a reasonable purchase.
One small nit - the HDMI LLC doesn't actually restrict the length to 25 feet. Physics of high speed signals and the current manufacturing processes restrict the distance to just over 25 feet. It's a nit but if someone came up with a passive cable that passed the eye tests at 30 feet, then that would be the new maximum distance.
alk3997 is offline
post #17 of 27 Old 02-20-2013, 04:58 AM - Thread Starter
Liked: 607
I guess it's worth a shot. I am in no rush, so I will keep this brand and costco on my radar so that I can pull the trigger when needed..
post #18 of 27 Old 02-21-2013, 02:49 PM
BlakRam's Avatar
I too was looking at the Costco cables...2 6ft for $25. Is the Monoprice cable the way to go or does it really matter??? Directv, ps3 and a 3d Samsung 7k series led.
BlakRam is offline
post #19 of 27 Old 02-21-2013, 03:08 PM
Colm's Avatar
Liked: 94
$25 for two 6' HDMI cables is not a great price.
Colm is offline
post #20 of 27 Old 02-21-2013, 03:13 PM
alk3997's Avatar
Liked: 93
I think it was the dual 6-foot cables that caused me to write, "However, the price is more than Monoprice would cost."
As long as they are certified High Speed from a capability standpoint it doesn't matter. Your bank account may be a different story.
alk3997 is offline
post #21 of 27 Old 02-21-2013, 03:52 PM
Doctego's Avatar
Liked: 42
I was eying down a pair of 9' high-speed cables at Sam's Club recently. Not for now but if I'm ever in a pinch. They were slightly less than $20 for both. Different brand, too.
We are here to help you. Please help us to help you. If you provide incomplete information, at best, we can give you an incomplete response.
Doctego is offline
post #22 of 27 Old 02-21-2013, 06:22 PM
BlakRam's Avatar
Monoprice cables are $27+ship for two 6ft's...what am I missing?
BlakRam is offline
post #23 of 27 Old 02-21-2013, 07:06 PM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 109
Monoprice has high speed 6 foot cables from $3.50 to $13.91 for the 6 foot RedMere it's Costco oranges and Monoprice oranges & apples thats what was missed. 12 foot high speed cables from $12.30 and a bunch of 15 footers from $15 to $21, not needing couplers at 2 bucks each or active ones from $13 to $19 to patch together the 2 Costco cables. The O P wants 25 feet of high speed and thats about $28 for a high speed 22 gage CL cable and around $45 for the RedMere.
post #24 of 27 Old 12-04-2016, 05:19 AM
Jasonn B's Avatar
Quoted: 369 Post(s)
Liked: 143
I have these same cables that I got 3 years ago from Costco,. I'm assuming these are still good and ok to use with a 4k tv?
80" Vizio LED - (60" Vizio plasma - retired)
Harmony 890 Remote
X10 Commander Iphone App = full control of lights, fireplace, pool, shades, from Iphone
X10 IR543 controller
Hunter Douglas motorized shades
Jasonn B is offline
post #25 of 27 Old 12-04-2016, 08:36 AM
Otto Pylot's Avatar
Quoted: 1591 Post(s)
Liked: 998
It depends on how long your cable run is. If you're trying to push 4k, 4:4:4 @60Hz over about 15' - 20' the answer is probably not. What's your distance?
Otto Pylot is offline
post #26 of 27 Old 12-04-2016, 09:31 AM
Jasonn B's Avatar
Quoted: 369 Post(s)
Liked: 143
6 foot. All 4 of them.
Jasonn B is offline
post #27 of 27 Old 12-04-2016, 12:44 PM
Otto Pylot's Avatar
Liked: 998
If your longest run is 6' then passive high speed HDMI cables will work for 4k. If you're trying to push the 4:4:4 @60Hz standard, they will probably be ok as well depending on the gauge of the wire. You don't need active cables. If you have any doubts, high quality passive high speed HDMI cables at 6' is not that expensive as long as you steer clear of Monster or AudioQuest.
Reply HDMI Q&A - The One Connector World
