Redmere High speed cable question... - AVS Forum | Home Theater Discussions And Reviews
Old 02-17-2013, 03:09 PM - Thread Starter
KBMAN's Avatar
Quoted: 255 Post(s)
Liked: 139
HAS ANYONE used a monoprice 'redmere' high speed cable at or above 30ft with success? And can you mix non redmere cables with this AND the Darblet??? Just wondering b/c my 35 ft slow speed cable is having some issues with blurays.
KBMAN is offline
Old 02-18-2013, 11:25 AM
alk3997's Avatar
Liked: 92
No such thing as "slow speed" cable - it's called a "standard speed cable". As I mentioned in the other thread, try 1080i with Deep Color off. If that works, it is likely bit errors.
alk3997 is offline
