only 1 HDMI port on TV and need to connect cable and PC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-21-2013, 12:04 PM - Thread Starter
trsonber's Avatar
Using a pro series sharp which only has one hdmi. I want to connect cable box, and PC. I also need sound from PC to TV so I was planning on using HDMI from PC to TV or some device in the middle. I need 1080P. Any suggestions on how to do this?
trsonber is offline
post #2 of 3 Old 03-21-2013, 12:29 PM
Selden Ball's Avatar
Quoted: 3200 Post(s)
Liked: 1571
Multiple-input HDMI switches are readily available. A Web search will locate more than you can take the time to consider. Monoprice is considered one of the better, cost-effective suppliers.
Selden
Selden Ball is offline
post #3 of 3 Old 03-21-2013, 03:31 PM
Joe Fernand's Avatar
Quoted: 299 Post(s)
Liked: 175
An HDMI Switch which also caters for VGA+Audio and YUV+Audio is one option.
http://www.octavainc.com/HDMI%20component%20%20vga%20Converter.html
You will want to set the PC Output to 1080p60 as there is no video ‘scaling’ going on within the Switch!
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is offline
Reply HDMI Q&A - The One Connector World
