redmere cable and HDMI-CEC ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-27-2013, 09:56 AM - Thread Starter
anarchoi's Avatar
Quoted: 14 Post(s)
Just discovered Redmere cables, i was wondering if those cables support HDMI-CEC ?
anarchoi is offline
post #2 of 4 Old 03-27-2013, 10:52 AM
alk3997's Avatar
Liked: 92
Yes. The cables doesn't know it is sending CEC. It's just a cable with a chipset that restores the signal on the sink side.
alk3997 is offline
post #3 of 4 Old 03-27-2013, 11:06 AM - Thread Starter
anarchoi's Avatar
Quoted: 14 Post(s)
It is a bit different than other cables
Note that HDMI Cables with RedMere are directional. One end must be connected to the source device (e.g., blu-ray player) and the other end to the sink/display (e.g., HDTV). Hooking them up backwards will not damage anything, they just won't transmit a signal. Also note that these cables are fully compatible with switches, splitters, matrix devices, etc. They can be used in any application in which a normal HDMI cable can be used and many applications where HDMI extenders would otherwise be required!
If it is only one-way then how can my TV send the HDMI-CEC signal to my receiver ?
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10255&cs_id=1025503&p_id=10206&seq=1&format=2
anarchoi is offline
post #4 of 4 Old 03-27-2013, 11:11 AM
alk3997's Avatar
Liked: 92
Because it isn't only one way. An HDMI cable wouldn't work if it only allowed one way communications. On Redmere cables, the high speed audio and video can only go in one specific direction since it is recovered at the sink, while the rest of the lower speed data flows in the direction it was meant to flow.
Since it is lower speed data it is less prone to have errors at longer distances.
alk3997 is offline
Reply HDMI Q&A - The One Connector World
