HDMI 1.2 pj, HDMI 1.4 cable and PQ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-29-2013, 03:26 PM - Thread Starter
niceguy88's Avatar
This may be the better place for this I hope. I've recently been running a small LED pj that has an HDMI 1.2 input via a Bluerigger HDMI to DVI (1.4?) at my desktop/video card.
Can a 1.4 spec HDMI to DVI cable cause picture issues with an HDMI 1.2 spec pj?
The picture plays fine, but the image doesn't look great color wise even after hours of tweaking off and on but most importantly, the picture is very soft to the point of being slightly blurry.
I've played with the PJ and nvidia video card settings and sharpness doesn't even do much of anything so I'm wondering if I should try another brand HDMI to DVI cable?
The thing is, I have to buy another 25' cable and wait most of a week to try it so I just wanted some input from you experts first.
Thanks folks!
niceguy88 is offline
post #2 of 3 Old 03-29-2013, 03:42 PM
alk3997's Avatar
Liked: 92
There are only two types of HDMI cables. They are High Speed and Standard Speed cables. Each type has a few options. These two types of cables were defined by the HDMI Org to simplify cable selection for a consumer. Both types of cables have the same pinouts. There is no such thing as an HDMI 1.4 cable (or any version number). It is simply a High Speed or Standard Speed cable and HDMI Org mandates that all the HDMI cables use that designator and never use a version number.
High Speed HDMI cables are capable of handling any HDMI signal currently used or planned. Standard Speed HDMI cable are guaranteed to be able to send 1080i and 720p images. Standard Speed cables may be able to handle high bandwidth signals such as 1080p/60, 1080p/24 2D or 1080p/24 3D, but it is not guaranteed. High Speed cables have passed tests to show that they can handle 1080p/60, 4K, etc.
http://www.hdmi.org/learningcenter/faq.aspx#49
The cable does not "know" what it is sending. It is a dumb cable. If only takes bits from one end of the cable to the other. The only thing you have to make sure is that the cable has enough bandwidth to send the signals you want without bit errors. Bit errors will show up as obvious screen defects such as lines, sparkles or screens that change to a solid color or even no picture at all. Bit errors do not cause loss of resolution or loss of contrast, color or anything else that is usually considered "picture quality".
So, for 1080p/24 3D or 1080p/60 2D you would want a High Speed HDMI cable and try to use ones that either provide the certificate online or have great user reviews, such as Monoprice or Blue Jean Cables or some of the others you'll find in this forum's archives. One warning is that some companies claim to have high speed cables that are not. Make sure you check reviews or see their certification. Sometimes they certify a shorter cable for high speed and then claim that longer cables are also covered. The longer cables are not. The maximum length for a certified passive High Speed cable is just over 25 feet (maybe 26 feet) .
Please note that I am unaware of any DVI to HDMI high speed cables. A DVI to HDMI adapter should provide you close to the bitrate of a high speed cable, if you use an HDMI high speed cable. You aren't looking to use the full bitrate of HDMI with your setup anyway.
(March 2013 Standard Answer Count = 2)
alk3997 is offline
post #3 of 3 Old 03-29-2013, 04:34 PM
Colm's Avatar
Liked: 94
Originally Posted by niceguy88 View Post
...I'm wondering if I should try another brand HDMI to DVI cable?!
If you aren't getting sparkles or worse, changing the cable will not improve your picture.
Colm is offline
Reply HDMI Q&A - The One Connector World
