50' Run to 2 TVs - AVS Forum | Home Theater Discussions And Reviews
Old 05-05-2013, 01:02 AM - Thread Starter
ronnymills's Avatar
I want to run a single HDMI cable 40' from my RX-v773 2nd HDMI port to a splitter. From there, 2 10' runs to identical 1080p TV's in kitchen and dining room. (HDMI1 out goes to another 1080p TV.)
Monoprice says I should put splitter at receiver and run two cables from there. It's already going to be a pain running the single cable up a wall and thru ceiling. How can I best accomplish this?
ronnymills is offline
Old 05-05-2013, 07:36 PM
alk3997's Avatar
Liked: 92
Yes the correct way would be to split at the source since then you are splitting a better signal. However, I have to believe that if you used a 35' Redmere (if that will work) and then two 15' High Speed passive cables it *might* work. The power for the Redmere comes from the sink, not the source, so a good (really good) splitter would be a must for this to work.
A much better way would be to use cat 6 cable instead.
Of course this is just 1080p so you're not using the whole bandwidth of HDMI. If 1080p/60 is all that you want, then it may work out. I'd make sure whoever you get this from has a good return policy since you really won't know if this works until you try it with your sources and sinks.
alk3997 is offline
Old 05-06-2013, 10:16 PM - Thread Starter
ronnymills's Avatar
Thanks for your insights. I think I will try the 'right' way the first time. smile.gif
Old 05-09-2013, 07:09 AM
AV_Integrated's Avatar
Quoted: 984 Post(s)
Liked: 728
If running the cables is a pain, then you really want to be sure that you pull Cat-X cabling while you pull whatever else you happen to pull. The use of HD-Base-T extenders is about the only way to reliably deal with potential long-run HDMI headaches which are otherwise very difficult to deal with.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
Old 05-10-2013, 08:08 PM - Thread Starter
ronnymills's Avatar
Old 05-15-2013, 05:14 AM
Joe Fernand's Avatar
Quoted: 285 Post(s)
Liked: 167
Hopefully the AVR offers HDMI Standby Passthru for HDMI Out 2?
Not a huge problem to place the HDMI Distribution Amp (DA) on the end of your 12m cable – as long as the DA is powered and not one of the ‘passive’ designs!
Do you need all of the Sources which are connected to the AVR available in your Zones B & C – we often find it’s just a Satellite Receiver or Cable box folk are trying to Distribute and if so I’d ‘split’ the signal before the AVR to avoid the complexity of running it via to AVR out to the extra Zones!
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is online now
