Component Only TV to HDMI HT. What do I need to make it work? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 06-11-2013, 01:09 PM - Thread Starter
woodyak's Avatar
I have an older 42" Panny Plasma that I'm putting in a vacation home. Ideally I'd like to get a converter so I can plug the TV into an HDMI HT system that will have a Blue-Ray player and DISH satellite connected/switched at the receiver. I'm trying to make this as simple and reliable as possible w/o spending big cash. What's out there for me?
woodyak is offline
post #2 of 10 Old 06-11-2013, 01:27 PM
AV_Integrated's Avatar
Quoted: 981 Post(s)
Liked: 722
HD Fury?
Otherwise, not much.
The TV doesn't have a DVI port on it or anything else? Just component video? This may prove to be a bigger headache than it is worth overall, and it may just be cheaper, in the long run, to get a cheap 42" flat panel. New ones can be had for around $400, and on sale for less at times.
http://www.hdfury.com/buy-hdfury-now/
A couple hundred bucks or so to do this on the cheap end.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #3 of 10 Old 06-11-2013, 01:32 PM - Thread Starter
woodyak's Avatar
Originally Posted by AV_Integrated View Post
HD Fury?
Yikes! That's freaking expensive.
Yeah, only component and RGB. I do think you could get a DVI card but its so old it might be hard to track down. What options would I have for DVI?
woodyak is offline
post #4 of 10 Old 06-11-2013, 02:55 PM
alk3997's Avatar
Liked: 92
And no guarantee that it will continue to work with Blu-Ray players. The members of the HDMI Org have always threatened to revoke the HDCP certificate that allows the device (and its siblings) to work. Everytime I see the device mentioned here, I wonder if we don't take a step closer to them doing that. They closed down component video outputs on new Blu-Ray players. The header to this forum still mentions how the HDMI Org was a contributor to this forum at one time so it wouldn't surprise me if some of the same people were still lurking.
alk3997 is offline
post #5 of 10 Old 06-11-2013, 02:58 PM - Thread Starter
woodyak's Avatar
Wow. What a PITA.
Oh well. I just found an older component switching HTS so I think I'll just do that and be done with it. All of my devices have component so that'll work just fine. Thanks for the help!
woodyak is offline
post #6 of 10 Old 06-11-2013, 03:59 PM
alk3997's Avatar
Liked: 92
Wow. What a PITA.
Best way to handle it - stay with the same connection type all the way through, when possible.
alk3997 is offline
post #7 of 10 Old 06-11-2013, 09:24 PM
Quoted: 981 Post(s)
Liked: 722
What Panasonic TV do you have?
I have a couple of HDMI cards for commercial Panny plasmas that I have no use for that I would donate if they were compatible.
post #8 of 10 Old 06-16-2013, 08:53 PM
TK Doom's Avatar
You could buy an Oppo-93 like I did for my 65" RPTV.
Course, thats expensive too, second hand on eBay.
They send blu-ray over component, if you don't have the bluray player already, might be a good investment. Quality blu-ray for the future as well.
TK Doom
Unreal Tournament Forever
Project Gotham Racing too!
TK Doom is offline
post #9 of 10 Old 06-17-2013, 09:14 AM
alk3997's Avatar
Liked: 92
Not guaranteed to continue to work at HD resolution over component. Blu-Ray has an Image Constraint Token that is option on all discs. If asserted, the ICT instructs the player to neuter the component video to 480p (actually a little better than 480p). That downrezzed version may then be converted back to 1080i for output, as strange as that sounds. So basically the player takes away the high definition detail and then the player tries to add it back electronically. All in the name of copy protection (supposedly)...
I know of only one disc that had the ICT asserted and there was some debate over whether it really was enabled.
alk3997 is offline
post #10 of 10 Old 06-19-2013, 03:39 PM
TK Doom's Avatar
I played probably 30 discs, no issues, but yes I know they could implement that.
TK Doom
TK Doom is offline
Reply HDMI Q&A - The One Connector World
