Ethernet over HDMI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-24-2013, 10:49 AM - Thread Starter
arie01's Avatar
Hello,
I have a question regarding Ethernet over HDMI.
Well, currently I’m not using any AV receiver because I’m in the middle of renovations. When all is done, I will finally connect all my equipment together.
My TV has an RJ45 jack and an optional WiFi (that I’m using for the past two years) and HDMI 1.4
My new receiver has an RJ45 jack and HDMI 1.4
My current cable box has HDMI1.0 (not used) but I’m going to replace it with a newer model that has an RJ45 jack and HDMI 1.3, I believe.
The newer cable box will be connected to the receiver with HDMI and from the HDMI OUT on the receiver, to HDMI1 on the TV.
Now, I planned on dedicating a switch port for every one of these devices. Then I saw that if the TV is connected to the Internet, all other supported devices can also be hooked up automatically through HDMI.
Is that true? Will all my supported devices be connected with a fully functional Ethernet connection that is 100Mbps fast?
Thank you,
arie01 is offline
post #2 of 5 Old 06-24-2013, 11:03 AM
Otto Pylot's Avatar
Quoted: 1416 Post(s)
Liked: 882
Not quite sure if this is the same thing but I'm planning on connecting a gigabit switch via Cat-6 cabling (solid core) to my router which is in another room. From the gigabit switch I'll connect the internet-capable devices using Cat-6 ethernet patch cable. HDMI from those devices to the receiver and then HDMI out from the receiver to the tv. High Speed HDMI is ethernet capable but I don't think there are any devices that take advantage of that protocol yet.
Otto Pylot is online now
post #3 of 5 Old 06-24-2013, 11:09 AM - Thread Starter
arie01's Avatar
So you are suggesting to stick with the original plan of using a Gigabit switch?
arie01 is offline
post #4 of 5 Old 06-24-2013, 12:02 PM
Joe Fernand's Avatar
Quoted: 299 Post(s)
Liked: 175
‘Ethernet over HDMI.’ – is a dead duck so forget about any ideas of using it.
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is offline
post #5 of 5 Old 06-24-2013, 12:06 PM - Thread Starter
arie01's Avatar
Thanks Joe, I just did. We'll go back to good old switches and cables...
Joe Fernand likes this.
arie01 is offline
Reply HDMI Q&A - The One Connector World
