HDMI to RCA Converter? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-14-2013, 03:01 PM - Thread Starter
legennd's Avatar
Hello All,
Hopefully, someone on here can help me. I plan on using a roku 3 with a projector. However, my projector only has 1 HDMI port and NO AUDIO OUT port. Now I have had luck using my speakers through my blu ray. I was wondering if there was a converter that will allow me to use hdmi with rca Thanks.
Ideally, I would want the picture to be HD and the audio would be through RCA. Is this possible?
legennd is offline
post #2 of 11 Old 07-14-2013, 03:10 PM
gregzoll's Avatar
Liked: 33
You mean something like this http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10114&cs_id=1011412&p_id=10251&seq=1&format=2 Instead of asking the question first, and having everyone else do the homework for you, you should really take the time to do the homework, and if you do not understand the product you found, then ask the questions.
gregzoll is offline
post #3 of 11 Old 07-14-2013, 03:15 PM - Thread Starter
legennd's Avatar
Yeah. I actually found it myself after I posted this.
legennd is offline
post #4 of 11 Old 07-14-2013, 03:15 PM - Thread Starter
legennd's Avatar
double post
legennd is offline
post #5 of 11 Old 07-14-2013, 05:09 PM
gregzoll's Avatar
Liked: 33
Edit your thread, stating that you found what you are looking for next time, or delete it, by clicking the Giant Red X, if you find what you are looking for, so that it does not get replied to.
gregzoll is offline
post #6 of 11 Old 07-15-2013, 08:07 AM
AV_Integrated's Avatar
Quoted: 1148 Post(s)
Liked: 825
I'm actually really interested in hearing how this product works, so would love some more replies as to the quality of this product, and perhaps any follow up recommendations if this product does not work.
There are a number of HDMI audio extractors on the market, and this unit from Monoprice is unique in that it handles DSP from HD audio sources which may be going through it and downmixes to two channel...
Love to hear how it works in this type of setup.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #7 of 11 Old 07-15-2013, 08:41 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 109
I can't speck to this unit specifically but as for Monoprice they have very good product quietly and stand behind them. I have used a converter that takes the component coaxial and digital coax or optical audio to HDMI. The only thing that was a problem for me is the LED on light is to bright and a little tape fixed that.
Phil17108 is offline
post #8 of 11 Old 07-15-2013, 09:06 AM
gregzoll's Avatar
Liked: 33
Someone posted the dimming dots, that you can place over LED's, that are overly bright. Not to go off track, but the largest complaint I see all the time, is the LED's for the U-Verse boxes, which I do not find as bright as those on the DirecTV boxes, which are really super bright.
gregzoll is offline
post #9 of 11 Old 07-16-2013, 09:43 AM
jautor's Avatar
Quoted: 1331 Post(s)
Liked: 852
The bright glowing ring on the DirecTV boxes can be dimmed / turned off. Press the LEFT and RIGHT arrow buttons together to cycle through the options. The box won't keep this setting through a power cycle / reboot, so it's also a good way to tell if your box has rebooted! biggrin.gif
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is offline
post #10 of 11 Old 06-03-2014, 08:03 AM
JustAnOldVCR's Avatar
Would have been more useful for someone to have replied to this with a product they actually have experience with using vs. just searching the monoprice site.  Instead weigh in on quality of DAC.  It is completely useless and a waste of time for others searching for similar issues.
JustAnOldVCR is offline
post #11 of 11 Old 06-03-2014, 03:40 PM
Liked: 825
Or you could ask if there's any update with people who may have used it.
I personally have used it now and can report that the Monoprice HDMI audio 'converter' worked very well for my installation and continues to work right now.
The setup:
2 HDMI inputs located at a conference room table.
HDBT extenders to the equipment rack (50' or so)
Monoprice audio extractors used before the HDMI matrix to take audio into the audio switcher.
HDMI video to a Gefen Toolbox 4x4 HDMI matrix.
Audio has consistently been pulled off the cable with no issue whatsoever and audio has been free from noise, pops, clicks, or hiss.
I have not tested these beyond this testing.
JustAnOldVCR likes this.
Reply HDMI Q&A - The One Connector World
