Problem with HDMI Splitter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-26-2013, 01:51 PM - Thread Starter
milktruck's Avatar
Hello all I bought a HDMI Splitter a few months back, it is a IKan Single Input/Dual Output Passive HDMI Splitter and I have it setup as follows.... HDMI Cable from Graphics Card to IN on Splitter, HDMI Cable from Monitor 1 to Out on Splitter and HDMI Cable from IN on Capture Card installed in my computer to Out. I use this setup so I can live stream video games while using 2 Monitors, my 2nd monitor is connected through DVI. Now everything works fine until I go to restart my computer, that is when my resolution gets changed to 640x480 and I can't change it to anything else. The only way to fix it is by disconnecting everything and reconnecting and restarting my computer. And just a few days ago I contacted IKan about the problem and they RMA'd me a new one which I got today, and now I'm having the same problem with the new splitter they sent me, and I am totally lost as to why this is happening, can anyone help?. I mean I know it's a cheap product..I only paid like $15 bucks for it, but still it works fine until I go to restart my computer. Any help on this problem would be greatly appreciated. Thanks
milktruck is offline
post #2 of 7 Old 07-26-2013, 02:55 PM
Colm's Avatar
Liked: 94
I have never seen a passive HDMI splitter that works properly. You need an active device with its own power supply.
Colm is offline
post #3 of 7 Old 07-26-2013, 06:52 PM - Thread Starter
milktruck's Avatar
Ok, can you recommend a decently priced one that has its own power supply and is around 30 bucks? I'm not really looking to spend more than that.
post #4 of 7 Old 07-26-2013, 07:22 PM
Keith Crusher's Avatar
Quoted: 12 Post(s)
Any of the HDMI splitters from Monoprice should do the trick and there are at least 2 models that are around/under $30. The cheapest one has some ugly reviews, but I've never had a problem with them - maybe I'm just lucky.
Keith Crusher is offline
post #5 of 7 Old 07-27-2013, 05:16 PM
alk3997's Avatar
Liked: 92
Be careful with that. Monoprice used to have a single splitter that got its power from the HDMI line. You could purchase an optional wall wart but it didn't come with it. I'm not sure if they still have that one available. They rest of the Monoprice line was good.
Basically make sure any splitter you get has an AC wall wart (or equivalent).
alk3997 is offline
post #6 of 7 Old 07-27-2013, 07:30 PM - Thread Starter
milktruck's Avatar
When you say wall wart I'm guessing you mean wall plug? cause I don't know what a wall wart is
post #7 of 7 Old 07-27-2013, 09:56 PM
Colm's Avatar
Liked: 94
Wall wart:
Colm is offline
Reply HDMI Q&A - The One Connector World
